I got it replaced at an independent mechanic. I was charged $655 ( parts + labour ).
Parts : Conductor Plate, Fluid, gasket, AT connector, AT filter.
Labour : 3.5 hrs.
Good for you. Maybe your car just needed a Transmission code reset.
Reason: update
Parts : Conductor Plate, Fluid, gasket, AT connector, gasket.
Labour : 3.5 hrs.
Thanks, but I am not holding my breath on that. So they replaced your new connector and I think that is wise. I do not see filter in there.
I have a road trip coming up (driving the wagon) and will order the conductor plate and replace it when I come back.
Op (Sri) had his conductor plate replaced by an Indie and all is well.
I replaced the conductor plate by myself today and all is also well. Here is a DIY writeup in PDF format (with photos) and also a picture of the valve body to get you in the mood reading the DIY article. It looks a little like open heart surgery, LOL.
We can happily close this thread now.
Edit: I re-uploaded the DPF file because I found a few typos.
Prof, congratulation, this is mission impossible for me. It should go to the sticky
__________________ iluvJESUS
"I am the Alpha and the Omega," says the Lord God,
"who is, and who was, and who is to come, the Almighty." Revelation 1:8
Thanks.
I thought so before as well because I had never opened up a transmission. Fluid/filter change was all I had done. However, with all the knowledge I accumulated, there is no fear. The key here is accurate diagnosis.
If my old back/brain can do it, your younger ones can also do it as well, probably faster and better.
No no, my brain is filled with fat and cholesterol, while yours is filled with knowledge and experience. Prof, do you have the WIS for cleaning fuel injector for 210.065? Thank you in advance, wanted to email you already, but since you are here, may as well ask here
I'll look. I doubt they have a cleaning article. They probably have a RR article.
What is wrong with your injectors? Slight leaking? Try some Techron first and it does wonders, especially to warn start issues.
