CV Boot Replacement? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 05-16-2009, 11:05 AM   #1 (permalink)
Date registered: Jul 2008
Vehicle: 1999 E320 4matic Wagon
Anyone have any DIY suggestions on how to replace two torn CV boots? Parts purchase? Tips? Special tools?
sleepysan is offline   Reply With Quote
Old 05-16-2009, 11:21 AM   #2 (permalink)
iluvjesus's Avatar
Date registered: Jan 2009
Vehicle: 210.065
Can I ask what is CV boot?
Would this help? http://www.youtube.com/watch?v=JZoa1hTM74U
iluvJESUS
"I am the Alpha and the Omega," says the Lord God,
"who is, and who was, and who is to come, the Almighty." Revelation 1:8
iluvjesus is offline   Reply With Quote
Old 05-16-2009, 11:35 AM   #3 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
CV is for "constant velocity" joint. There are two for each driveshaft, with rubber boots to contain the oil and keep the dirt out.
Astoria makes a boot called Flexx which can be stretched over the joint, using a special tool (either a very strong cone, or an air-powered spreader).
Old 05-16-2009, 11:45 AM   #4 (permalink)
iluvjesus's Avatar
Vehicle: 210.065
Thank you Matt.
Old 05-16-2009, 12:28 PM   #5 (permalink)
Kajtek1's Avatar
Vehicle: W210 E300DT x2 / Ford SD, JDtractor. Seeking diesel lawnmower
I think I post some experience when I was replacing the boot few years ago, but it is probably in the forum archives. Just like the video shows -all it takes to separate joint from the axle is a good swing with right hammer. I did it without removing the axle from the car, and since I was saving the joint -I used brass punch what added some difficulty, but it worked.
Kajtek1 is offline   Reply With Quote
Old 05-19-2009, 02:55 PM   #6 (permalink)
Thanks Kajtek1. I will be saving the joint as well. Recommend any parts supplier?
Old 05-19-2009, 02:57 PM   #7 (permalink)
Kajtek1's Avatar
When I did the joint, the dealers "didn't do the boots" (gladly offering you $1200 axle) and I had to get it from aftermarkets.
Have seen somebody posting here a supplier at later time.
Old 05-19-2009, 02:57 PM   #8 (permalink)
Would this help? YouTube - Replacing A Broken CV Joint Boot
thanks for the link. nice job.
Old 05-19-2009, 03:35 PM   #9 (permalink)
iluvjesus's Avatar
Vehicle: 210.065
Just in case, is yours a 4matic, Loubapache has just complied an very important sticky for 4 matic, and CV boot is one of the topics.
http://www.benzworld.org/forums/w210...ml#post2914140
Old 05-19-2009, 05:35 PM   #10 (permalink)
Musikmann's Avatar
Vehicle: 2001 E320 - Brilliant Silver/Ash: 99,000+
Off topic but I'm going through this with my Toyota right now. An Indy found a leaking CV boot on it today and their fix is to replace a 1/2 axle. Remanufactured part is $99.50 with $150 labor.
Just to add, this is the 2nd go around for these. Both 1/2 axles had leaking boots at around 75,000 miles on the car. It now has 117,000+ and the 3rd is shot. What I don't know without further research is how many years it has been since the other failures. Not that I'll add to this OT, but it's something I'm curious about.
Musikmann is online now   Reply With Quote
Bookmarks
Inner + Outer CV boot Replacement ??? 300sd W126 S,SE,SEC,SEL,SD,SDL Class 12 08-23-2009 09:55 AM
Rack Boot Replacement blm W210 E-Class 15 08-06-2008 05:07 PM
CV boot replacement Cyberbach W123 E,CE,D,CD,TD,TE Class 12 11-16-2007 06:38 PM
Axle boot replacement tool Trevor Sarty W123 E,CE,D,CD,TD,TE Class 0 04-11-2007 04:56 AM
Shift Boot Replacement EternalE W124 E,CE,D,TD Class 3 02-02-2006 01:58 PM
