Engine rattling noise at idle - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 02-09-2009, 05:04 PM Thread Starter
Date registered: Sep 2007
Vehicle: 1998 E320
Quoted: 2 Post(s)
My 98 E320 70k miles is making a rattling sound from the engine bay at idle once the engine has warmed up. It can only be heard outside the car. I took off the plastic cover and can't seem to pinpoint where it is coming from. Any ideas?
cgrizzly888 is offline
post #2 of 15 (permalink) Old 02-09-2009, 06:09 PM
Scuddog's Avatar
Date registered: May 2008
Vehicle: 1998 E320
Could it be coming from the exhaust cats? Are you certain that the noise isn't coming from your catalytic converter(s)? Lean under the car near the front doors and see if the noise is stronger under the car. Your miles are about right for a cat failure. If that's it... $600 each.
"To be admired by fools is no compliment."
1998 E320
240,000+ Miles
Original transmission, engine & flux-capacitor
See-thru glass, roll-around tires, shiny stuff too
250,000 KM High Mileage MB Certification
Interstate Cruise Missile
Scuddog is offline
post #3 of 15 (permalink) Old 02-09-2009, 07:06 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hey cg. Please click the user cp link and complete your BW profile re vehicle and location as that is often useful information.
Here, for example, if you are in the US -- but NOT CA -- and it is your cats, there are universal cats that can be welded in quite affordably.
However, you need to properly diagnose this. The only noise I can think of by your terse description is also cats. But you have FOUR cats, two on each side, and if you can't isolate it you'll have to take it in. A mechanic's stethoscope will help isolate such noises.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #4 of 15 (permalink) Old 02-09-2009, 08:07 PM Thread Starter
Vehicle: 1998 E320
Quoted: 2 Post(s)
Thanks for the info. Are the 4 cats located underneath the engine? It sounds like it's coming more from the top of the engine and something is loose and rattling. I will check to see if the noise is louder under the car tomorrow.
post #5 of 15 (permalink) Old 02-09-2009, 08:49 PM Thread Starter
Vehicle: 1998 E320
Quoted: 2 Post(s)
Since my car is under 80k miles, would MB replace the cats under warranty?
post #6 of 15 (permalink) Old 02-09-2009, 09:11 PM
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(205K Miles), 2002 E320 Special Edition(174K Miles)
Nope, it's out of the 8 year limit.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline
post #7 of 15 (permalink) Old 02-09-2009, 09:55 PM
Quoted: 35 Post(s)
The primary/front cats are visible from the engine compartment, just ahead of the position 1 O2 sensor and after the header. The secondary/rear cats are laterally close to the front of the transmission underneath the car after the position 2 sensor. There have been problems with both, I think in the earliest V6 years it was more the primary cats, then the secondary.
Don't make this harder than it needs to be. Get a mechanic's steth and you'll easily isolate it. If you have a Harbor Freight nearby they're like $3. You'll need it anyway to isolate other noises like WP bearings, tensioner bearings, idler bearings, etc.
Greg
post #8 of 15 (permalink) Old 02-09-2009, 10:48 PM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 7 Post(s)
Is it a loud
rattle or a light drum like ticking?
On the top side of the engine in front of the brake booster is a object labeled MOT,that is your purge valve.It will tap away like a little drummer.Normal.
If under the car,get it on a lift and check for the sound coming from the cats.You are in NJ so eastern cats has universal unit that are about $50 each and can be spliced in by any good custom exhaust shop.
Keep us posted ,when you locate the sound.And as always be careful working around moving parts while trying to locate a sound with the car running.
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #9 of 15 (permalink) Old 02-10-2009, 06:51 AM Thread Starter
Vehicle: 1998 E320
Quoted: 2 Post(s)
I didn't get a steth yet, however, I noticed my belt tensioner has excessive movent. It moves side to side while the engine is moving. I wonder if this is causing the rattle noise.
post #10 of 15 (permalink) Old 02-10-2009, 10:12 AM
Quoted: 35 Post(s)
That would indeed do it. If it has free play (check it with the engine OFF, just grab it and move it up/down, in/out top out/bottom in and vice-versa) then stop driving the car and replace it. If it has enough free play to make noise and be felt/seen it is due to let go at any time and you'll be stranded. If you don't want to wait for shipping just get the part at your dealer, obviously it will cost more but you'll be on the road sooner. You should be able to just buy the pulley with the bearing instead of the whole tensioner assembly, that's lots cheaper and usually the part that fails anyway.
Greg
2000 E320 Wagon Rattling Noise...Catalytic Converter/ROUGH IDLE PROBLEMS AND NOISES!! peter18 W210 E-Class 27 10-08-2008 05:47 PM
Rattling Engine Noise unhappy Kamper R170 SLK-Class 24 07-15-2008 05:44 PM
Rattling noise - Don't think it's engine mounts bvmags W124 E,CE,D,TD Class 8 12-12-2006 05:32 AM
Engine Rattling Noise frost_dxb W203 C-Class 0 09-19-2005 11:15 PM
Peculiar rattling at idle from engine by oil fill?? Joe W163 M-Class 5 04-16-2002 10:10 AM
