Very loud knocking sound from engine at start-up. - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 01-30-2009, 05:36 AM Thread Starter
dacia's Avatar
Date registered: Sep 2004
Vehicle: 2000 E320 aka Reichrocket
Quoted: 17 Post(s)
MY 2000 E320 60K miles. We travelled to Europe for a week and left the car at an airport parking where they move cars around.
Came back this morning (7 days later), started the car up and a very scary, loud knocking sound came from the engine. I shut it off immediately and asked the attendant what the h*ll happened to my car. He said they parked the car there last night and there was nothing wrong with it. I started her up again, same noise. It came from the head, towards the back of the engine. I shut her off again, checked the oil, no leakage, normal level. I started again, the noise somewhat subsided and slowly disappeared in less than a minute. They said they didn't touch the engine, they just parked the car there. I drove home (about 100 miles) and everything is fine, so far. I will not drive it over the weekend, the next time I will start it up will be on Monday.
It sounded like an engine running without any oil in it, or having a bearing problem. I checked the oil level, it is down just a bit, maybe 1/4 quart/liter. I thought maybe the valve in the oil filter housing is defective and all the oil from the head leaked back to the engine hence the dry running on start-up. I had parked the car for 3 - 4 days before and have never experienced this problem.
I had owned a couple of Benzes and parked them for 2 weeks at a time and never a problem when starting up. Any idea as to what caused the sudden dry running? If indeed that is what it was, but the fact that the sound disappeared soon after starting her the third time makes me believe that it was a lubrication problem.
Out side temperature is above freezing, according to the mileage they didn't drive the anywhere except shuttling between their parking lots.
I got home around 3pm and parked the car. Just went down to start her, it is 10:30pm now, and it runs just fine.
Any ideas would be appreciated.
Alex
dacia is offline
post #2 of 11 (permalink) Old 01-30-2009, 09:11 AM
Kajtek1's Avatar
Quoted: 1250 Post(s)
We have our MB sitting for 5 weeks all the time with no ill effects.
The only thing that poops into mine mind is that leaky injector flooded the cylinder and was on the edge of hydraulic lock.
Did you record the mileage before leaving the car at parking lot? What is the guarantee the parking attendant didn't take it for joy ride?
Kajtek1 is offline
post #3 of 11 (permalink) Old 01-30-2009, 10:48 AM
Olivier A's Avatar
Date registered: Jun 2008
Vehicle: E300TD 1997 W210 Running on WVO and a % of dino...
Is it a diesel? If so might be one or few glow plugs that are gone.
Olivier A is offline
post #4 of 11 (permalink) Old 01-30-2009, 03:45 PM
'91 300CE's Avatar
Date registered: Jul 2006
Vehicle: 2002 ML320
No the 2000 E320 is a Gasser...
Sounds like from them running the engine for extremely short stints (to just move the car around) that not enough oil pressure was built up in the engine on top of all the oil draining out of the engine into the pan while it sat for long periods that it just needed to get the oil flowing again.
2005 BMW 325Ci - Sport, Premium and Cold Weather Pkgs
2000 C230K -- Desert Silver Metallic -- 113,000 miles -- Sold
2002 ML320 -- Alabaster White
1991 300CE -- Blue Black Metallic -- 129,000 miles -- Sold
1981 300SD -- Classic White -- 190,000 miles -- Sold
1977 240D -- Over 300k miles (Wrecked) -- My 1st car
2006 Porsche Cayenne S - Dad's
2004 Porsche 911 Turbo S
'91 300CE is offline
post #5 of 11 (permalink) Old 01-31-2009, 06:06 AM
citruspilot's Avatar
Date registered: Dec 2006
Vehicle: 06 CLS500, Boeing-737, 04 Tahoe LT, 04 Infiniti G35 Sedan
Do the 6's have oil feed tubes? Maybe one of them has failed like the 420's do......... Just a thought.
Jeff
citruspilot is offline
post #6 of 11 (permalink) Old 01-31-2009, 06:08 AM Thread Starter
dacia's Avatar
Quoted: 17 Post(s)
It is not a diesel, it runs on gas.
The mileage looked about right, I didn't actually write it down before leaving the car.
What are symptoms of a leaking injector?
Well, it will sit for the weekend and I will see if the problem reoccurs on Monday morning.
It has another problem as well with excessive shaking when started cold. It is more noticeable when in gear and doesn't disappear even after driving on the highway for 30 minutes. It is more apparent in cold ambient temperatures. Any ideas?
Car is well maintained and driven normally including the occasional "Italian tune-up", i.e. driving over 180km/hour speed.
Thanks for the input/ideas.
Alex
dacia is offline
post #7 of 11 (permalink) Old 01-31-2009, 09:13 AM
Kajtek1's Avatar
Get infra-red thermometer and compare the temperatures of each cylinder. That might pinpoint bad cylinder/injector.
Kajtek1 is offline
post #8 of 11 (permalink) Old 01-31-2009, 10:05 AM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 5 Post(s)
If it cleared up
and you have no codes showing,it could be that simply sitting caused some fuel to sit in an injector and leak into a cylinder.Starting the engine caused the disruption in the firing order.
Run a can of seafoam injector cleaner through the tank when it is half full and keep us posted if any check engine lights come on or the problem returns.
I doubt it will
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #9 of 11 (permalink) Old 01-31-2009, 12:57 PM
Scuddog's Avatar
Date registered: May 2008
Vehicle: 1998 E320
Be wary of classifying this noise as the oil passages failure. Try the Seafoam route, take two aspirin and call us in the morning...
"To be admired by fools is no compliment."
1998 E320
240,000+ Miles
Original transmission, engine & flux-capacitor
See-thru glass, roll-around tires, shiny stuff too
250,000 KM High Mileage MB Certification
Interstate Cruise Missile
Scuddog is offline
post #10 of 11 (permalink) Old 02-01-2009, 07:10 AM Thread Starter
dacia's Avatar
Quoted: 17 Post(s)
Well, you guys are rather optimistic. :-) I will drive the wife's A160 on Monday (as it has been sitting for almost ten days and the battery needs charging) and start up the E320 on Tuesday. I will post any negative result.
Alex
dacia is offline
    LOUD KNOCKING ENGINE AZIRRIGATION W126 S,SE,SEC,SEL,SD,SDL Class 13 05-11-2012 06:21 PM
    front engine knocking sound??? SikSlk99 R170 SLK-Class 4 12-23-2008 01:17 AM
    Not so loud but annoying rattling sound at start sergiu W163 M-Class 13 07-17-2008 07:05 AM
    E220 Cabrio Loud knocking noise Benji P W124 E,CE,D,TD Class 0 07-14-2008 01:56 AM
    Strange Engine Sound - The Start of Engine Problems??? SLKDUDE R170 SLK-Class 3 04-28-2001 10:38 AM
