Engine Oil Leak - Mercedes-Benz Forum
post #1 of 52 (permalink) Old 01-11-2009, 09:14 AM Thread Starter
Date registered: Aug 2005
Vehicle: 1999 E320, 2001 E320
Quoted: 13 Post(s)
Engine Oil Leak
1999 E320, Oil leak, what does it take to fix the leak? Do they sell a gasket to replace the original one? should I use a glue type of gasket forming material? Does anyone have experience with this?
If it's left alone not repaired, will it do any harm?
Thanks for your help.
cerritos is online now
post #2 of 52 (permalink) Old 01-11-2009, 09:17 AM
Date registered: Nov 2005
Vehicle: 1996 210.020
Where is it leaking?
Matt L is offline
post #3 of 52 (permalink) Old 01-11-2009, 09:43 AM Thread Starter
Quoted: 13 Post(s)
That's a good question. I don't know.
The area is under the air intake with electronics attachment. I have to disassembly many things to identify it. I'm assuming it's some kind of gasket.
Name:	Copy of IMG_2460.jpg
post #4 of 52 (permalink) Old 01-11-2009, 10:06 AM
It could be the valve cover gasket (is that your valve cover in the picture?), unless it's a crankcase vent that is leaking instead. You may have to clean it up a bit to identify what is actually leaking, but I would check the valve cover fasteners first. Don't crank on them, just check to ensure that they're all at least finger-tight.
Matt L is offline
post #5 of 52 (permalink) Old 01-11-2009, 12:56 PM Thread Starter
Quoted: 13 Post(s)
Originally Posted by Matt L View Post
It could be the valve cover gasket, unless it's a crankcase vent that is leaking instead.
This is the first time I've heard of the term "crankcase vent". Looking at the picture, it looks like some kind of "vent" leaking. ??
I guess so.
Good idea. I'll do that. Thanks.
This is a 1999 E320. Does anyone else have the same problem? I'd think that there are many 1999 E320's having similar problem.
post #6 of 52 (permalink) Old 01-11-2009, 04:19 PM
While you may not have heard of "crankcase vent," all cars have them. In the old days, it was referred to as the "PCV system" with the associated "PCV valve." PCV means Positive Crankcase Ventilation.
All engines have crankcase vents. In the (very) old days, they were simply routed to the atmosphere. As of the last fifty years or so, the crankcase gasses have been vented to the intake manifold to be burned.
Matt L is offline
post #7 of 52 (permalink) Old 01-11-2009, 08:20 PM
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(203K Miles), 2002 E320 Special Edition(174K Miles)
This is an extremely common problem on the M112 engine. It is leaking from the breather cover(s), with leaks on the passenger side more common. On both my E320 and SLK320 it started leaking at about 90,000 miles. Here is a picture of mine that I posted about 6 months ago. http://www.benzworld.org/forums/w210...aking-oil.html
It does not have a gasket and you need to use "gasket maker" compound. I did it about 2,000 miles back on my SLK and will do it on my E320 as soon as it gets to the next oil change. It is not a very difficult job, but it does take a lot of time to clean the covers properly. I took me about 2 hours to do the passenger cover, 10 minutes to remove, 1 hours 30 minutes to clean, 10 minutes to apply the gasket maker and 10 minutes to re-install.
I used this article as a basic guide: Resealing the Recirculating Cover on M112s - CrossfireForum.org
It was posted in the Crossfire forum, but is EXACTLY the same as my SLK320. There is a slight difference in the E Class, in that we have an additional intake damper that have to be removed or swung aside. The most important thing if you use the method in the article, is to ensure that none of the old gasket ends up in your engine. After removing the breather covers, I first dried the chambers completely with paper towels, making sure to suck up all standing oil. I then plugged the 3 holes with paper towels. Only after this did I start removing the old gasket, always cleaning to the outside of the chamber. Once cleaned, I vacuumed the chamber out and gave it another good wipe-out. To clean the gasket from the breather cover, I used some brake cleaner aerosol as an initial starter, followed by manual cleaning.
O yes, very important!! You'll notice that some of the threads refer to an 8Nm torque. That ONLY applies to the large bolts - NOT the small ones. (Don't ask me how I found that out )
In spite of what some people believe, you don't have to go to the MB dealer to buy the gasket maker. Permatex Black works perfect.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline
post #8 of 52 (permalink) Old 01-11-2009, 11:00 PM Thread Starter
Quoted: 13 Post(s)
Thanks for the valuable information. That's what I thought, it's a common problem.
What's the torque for the smaller bolts?
post #9 of 52 (permalink) Old 01-12-2009, 07:53 AM
Date registered: Feb 2008
Vehicle: mercedes benz W210 e240
dear benz owners,
i also have the same problem. I have an M112 engine. According to my mechanic it was the head gasket that was causing the problem. According to him it was a common problem. It would cost around 2000 CHF to get the problem fixed. Is he lying to me or is this price reasonable. I was thinking of using a fuel additive called STOP ENGINE OIL LEAK produced by stp. Also will using this additive cause any harm to my engine??
mbe240 is offline
post #10 of 52 (permalink) Old 01-12-2009, 10:50 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Originally Posted by mbe240 View Post
dear benz owners,
First, I would not suggest the use of any oil additives and I'm pretty sure no one here will recommend them to you. The only exception would be an engine that is really just shot and you're adding thickeners to slow horrible leaks or blow-by, but that's just a stopgap solution until rebuild time in the immediate future.
The M112 is NOT known for head gasket problems and if you have an oil leak on top of your valve covers then it is NOT the head gasket. The head is below the valve cover and the head gasket is between the head and the block, so the oil would have to travel a bizarre path upwards for a 1/3 meter or more, which doesn't happen. So if you've got the film displayed in the OP's pictures up atop the valve cover, then do the fix Kobus posted and you'll be good to go. (And if that is the leak location I'd think about finding another mechanic...)
Take care and enjoy the ride,
Greg
Check Codes is offline
    engine oil leak? k85o91 C208/A208 CLK-Class 0 06-18-2006 10:45 PM
    Engine Oil Leak ///S320 W140 S-Class 0 03-23-2006 04:39 AM
    Engine Oil Leak pchansen1 W140 S-Class 8 12-18-2005 08:02 AM
    ENGINE OIL LEAK MOBBOSS42 W126 S,SE,SEC,SEL,SD,SDL Class 3 06-23-2004 05:24 PM
    My 96 S320 to have a cracked engine block gasket, which cause a oil leak .All oil changes (more)... Guest (MBNZ) W140 S-Class 2 04-19-2002 01:34 PM
