PO400 EGR Flow Malfunction - Mercedes-Benz Forum
post #1 of 33 (permalink) Old 01-09-2009, 07:54 PM Thread Starter
Vehicle: 2008 BMW 528i,1999 Lexus 400LS, 2014 e250 BlueTec
Quoted: 4 Post(s)
Send a message via MSN to Raylee177 Send a message via Yahoo to Raylee177
My friend's YR 2000 E320 is showing "Check Eng" with Code PO400 EGR flow malfunction. Can somebody help me with this. Thank you in advance.
Raylee177 is offline
post #2 of 33 (permalink) Old 01-09-2009, 09:16 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hey, Raylee.
I can't tell you exactly what part of the EGR that pertains to, nor am I sure how precise the codes are. That said, this is how I'd proceed.
1. Disconnect the vacuum line from the EGR valve and fit a longer piece of hose on it. Suck on it and be sure the diaphram holds vacuum (if you have to keep sucking on it that is bad). If it does not hold vacuum, replace the valve.
2. Remove the little plastic check valve (one end won't be connected, this is normal). Note which end is plugged in. Inspect it for cracks/damage and suck on it. It should allow air flow in one direction only. If it is suspect, replace it.
3. If it checks out thus far, then remove the EGR valve and tube. Clean both thoroughly (the tube can be particularly troublesome to clean, pipe cleaners can help) and check the diaphram (again) and make sure the mechanism moves smoothly (visual check) when you apply vacuum. If not, replace it.
4. Inspect the gasket for damage, if any is present, replace it.
5. Replace/clean/reinstall as necessary.
Reset codes and drive car, see if the issue is resolved.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #3 of 33 (permalink) Old 01-10-2009, 07:23 AM Thread Starter
Quoted: 4 Post(s)
Gregs210,
You have been my help in the past, too. Thanks again, I will try your recommendation.
Another issue, do you think German Start MAF insert is OK to use?
post #4 of 33 (permalink) Old 01-10-2009, 09:11 AM
Date registered: Nov 2005
Vehicle: 1996 210.020
German Star? Should be fine.
Matt L is offline
post #5 of 33 (permalink) Old 01-10-2009, 10:56 PM Thread Starter
Quoted: 4 Post(s)
Matt L,
Thank you very much. I received the part yesterday and found no Bosch marking on it. But it has been installed. I will try out tomorrow on the road.
EGR issue,
All I had to do is to clean the valve with CRC. It was stuck fronzen but with CRC I was able to make it loose. I cleaned it until I could see the valve move in and out nicely.
post #6 of 33 (permalink) Old 01-10-2009, 11:55 PM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 5 Post(s)
only
33 bucks more for the whole bosch maf and autohausaz.com ships for free so it is only about $25 more out of pocket.I like the inserts but for only 25 bucks more a brand new complete unit is more attractive evry day
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #7 of 33 (permalink) Old 01-11-2009, 06:10 AM
Vehicle: Mercedes W210 E320 wagon
This is how it looks like in pictures.
EGR Part#A112-140-0108 . I found OEM for ~$80. You can buy it or you can clean up existing pipe.
This is a process.
You will need:
- wide, flat screw driver (I used it for removing vacuum lines).
- ratchet 3/8"
- extensions 3/8" (for ratchet)
- flexible extension 3/8" (for socket)
- Torx: E10 and E12
- Open-end wrenches: 22mm and 24mm
- thin and long pliers (I used for setup injector switch brackets. I couldn't reach it by fingers).
- torque wrench 3/8"
- Bolt locker. I used "Prime Lock 245 Blue threadlock formula".
- CRC Throttle Body & Air-Intake Cleaner (~$4).
- Sea Foam Motor Treatment (~$8)
- piece of metal cable. I made brush from it. Very last picture shows how to use it.
Open engine cover.
Remove MAF
One torx keeps intake pipe.
Removed intake pipe
This is pipe, which you have to clean up.
Cleaning tool .
Bansai is offline
post #8 of 33 (permalink) Old 01-11-2009, 07:53 AM Thread Starter
Quoted: 4 Post(s)
Bansai,
Your picture help it me very much. When you took out the whole EGR assembly, did you have problem with gaskets breaking? I was afraid of it so I cleaned valve only without taking it out.
post #9 of 33 (permalink) Old 01-11-2009, 08:26 AM
Originally Posted by Raylee177 View Post
Bansai,
Great! I know what you are talking about. I didn't have any issues with gasket. I just carefully removed it and cleaned by paper towel with Sea Foam.
Bansai is offline
post #10 of 33 (permalink) Old 01-12-2009, 06:50 AM Thread Starter
Quoted: 4 Post(s)
Only those who have experienced personally will really appreciate value of you guys assistance. Oh, what a feeling when problem is fixed with your help without going to stealership!
Happy New Year to all you good people!
    EGR Malfunction - Code P0400 UncAl W163 M-Class 8 12-25-2011 09:11 PM
    EGM Valve, Diagnostic code PO400 Endo-E W202 C-Class 1 04-22-2007 10:48 AM
    C280 P0400 EGR Malfunction Dennis78 W202 C-Class 2 04-07-2007 01:43 AM
    po400 4maticinmedford W210 E-Class 0 06-20-2006 01:31 PM
    P0400 EGR Flow Malfunction cure - See photos ScubaDriver W163 M-Class 3 12-23-2004 06:07 PM
