E430 Sport tune-up - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 12-31-2008, 12:11 PM Thread Starter
Date registered: Dec 2008
Vehicle: 1999 Mercedes E430 Sport
E430 Sport tune-up
Hi,
I have a 1999 E430 sport. I bought it in late '03, and it been a pretty descent car. Aside from the crazy electrical issues (that seem to self-heal), I've had a blown transmission (planetary gearset) and for some reason the front upper support for the coil spring support just decided to break off. I do almost all of my own maintainance and repair, but I think its time for a tune up. I'd like to change the plugs, and I seem to have OK access to them. I've given the wires a good pull, but they don't want to come off of the plugs. I don't want to pull too hard and break something. Is there a special tool to remove the wires from the plugs? So during this tune up, I want to:
Replace air filter
Change the oil and filter
Change the plugs
Flush cooling system and replace coolant
Change climate control air filter (if easily accessible)
Check brake pad wear and replace as needed (already done once)
Inspect the serpentine belt
Inspect coolant hoses
Is there anything else that a home mechanic can do that should be looked at on this model? the car has 130000 miles on it.
drfeno is offline
post #2 of 10 (permalink) Old 12-31-2008, 12:14 PM
Date registered: Nov 2005
Vehicle: 1996 210.020
That sounds like a pretty good list, but you might want to also change the transmission fluid.
The climate control air filter is not hard to replace, but pulling the glove box out the first time is a bit scary.
Matt L is offline
post #3 of 10 (permalink) Old 12-31-2008, 12:14 PM
And welcome to the forum. Please take a moment to complete your user profile ("User CP" link) with your location and vehicle model/year.
Matt L is offline
post #4 of 10 (permalink) Old 12-31-2008, 01:19 PM
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320 2010 2011 E350 2016 GLA250
Quoted: 130 Post(s)
I would also add:
Fuel Filter
Differential Oil
Power Steering Fluid
G-AMG is offline
post #5 of 10 (permalink) Old 01-01-2009, 11:59 AM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 5 Post(s)
Don't pull
on the wires
That is why you can get the proper 17mm boot removal tool from me for a delivered price
You need to get onto the metal boot and pry it off.If you yank the wires you will be buying a new set of wires when you are done cussing all day about the misfires you caused on wires that will last forever if not abused.
trans fluid and filter spec fluid
bleed the brake fluid properly
change ps fluid
check motor mounts and trans mounts and front end bushings and ball joints.
At 130k shocks are past due
if you know that it had the proper service done at 100 k miles you have a long while before it needs plugs(100k mile change intervals)
O2 ssensors were due to be changed at 100k if they were not you are not getting the best performance and mpg out of your MB
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #6 of 10 (permalink) Old 01-03-2009, 11:12 AM
Date registered: Sep 2008
E430 spark plug removal
I have a 2001 E430 and it needs to have the spark plugs changed. We cannot figure out how to get access to the wire. I see where someone recommended a 17mm boot removal - any idea where I buy one of those?
thanks.
dsomimi is offline
post #7 of 10 (permalink) Old 01-03-2009, 02:20 PM
ohlord's Avatar
Quoted: 5 Post(s)
Look at the
post just above your post Read it to discover the path to nirvana
a Mercedes Benz"
ohlord
ohlord is offline
post #8 of 10 (permalink) Old 01-04-2009, 09:20 AM
OhLord - thanks for pointing me to where I can buy the tool. I noticed that the decsiption of the tool states that this works on 6 cylinders, the 430 is an 8 cylinder....does this tool fit these plug boots as well.
Also, how does the tool work? when I look at the boots, they don't appear to have a shape that a wrench would fit and if I turn them they just spin, they don't turn off. Does this tool pry them off?
Thanks
dsomimi is offline
post #9 of 10 (permalink) Old 10-08-2014, 11:12 AM
Date registered: Oct 2014
Vehicle: 2002 Mercedes E430 Base
I have a 2002 E430 it pull code p0304 # 4 clylinder is dead. which would you try first plugs, coil pack or wires?
santana219 is offline
post #10 of 10 (permalink) Old 10-08-2014, 11:57 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Purely as a matter of forum etiquette, unless your post directly connects to the thread, it's better to start a new thread than hijack an old thread.
Please also take a moment to click user cp and edit details so that you can easily add your vehicle and location to your profile. It's often useful information when you're seeking assistance.
As to your specific issue, I would first swap the coil pack to another cylinder. Probably #1 as it's easier to get to.
Reset codes, go driving. If the same code recurs, I'd then swap the ignition wires with the same cylinder as before (treat them gingerly and be sure to maintain polarity!).
Reset codes, go driving. If the same code recurs, I'd replace the plugs in #4 .
Reset codes, go driving. If the same code recurs, I'd swap the #1 and #4 injectors, renewing the seals on them at the same time.
Good luck.
Check Codes is offline
    Sport Grill on E430 Sport? acarter53 W210 E-Class 18 03-31-2008 07:27 PM
    Pictures of my New used E430 Sport mildbrew W210 E-Class 35 03-06-2008 11:03 PM
    Just purchased E430 Sport Bubbenz W210 E-Class 4 09-29-2004 06:25 PM
    Sport appeal for E430 shiraz W210 E-Class 13 09-09-2004 08:19 PM
    01 E430 Sport wheel Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 10-10-2001 02:48 PM
