Added R134a-fixed hissing sound, however ac fan runs fast on/of, did I overcharge? - Mercedes-Benz Forum
post #1 of 25 (permalink) Old 11-29-2008, 09:18 AM Thread Starter
Date registered: Sep 2008
Vehicle: Mercedez Benz E320
I ran onboard diagnosis after refilling R134 a(approx 34 ounces) on the low pressure port per DIY.
2 Issues:
1. Refrigerant pressure(on test #7) fluctuates between 13-17, up and down as time elapses while I perform diagnosis. Did I overcharge?
2. When I turn on AC, the fan by radiator runs very fast no weired sound but I have never heard it run that fast with a weeeeimng sound! The fan speed runs fast then gies down as along as AC is running. !Weeeeing......then slows down, then 'weeeing!!! Is this normal when AC is on? It feels like it is adjusting to cool levels automatically but boy it its is too frequent!
My post R134 pour, onboard diagnostic did not return any Error other than the E FF. Any advice?
1 73
2 93
3 87
4 87
5 37
6 181
7 14-17 This fluctuates
8 96
The gauge that came with R134a does not work well(why buy it and the car has onboard diagnostics? jut FYI
Thanks!
jchumba is offline
post #2 of 25 (permalink) Old 11-29-2008, 09:55 AM
Kajtek1's Avatar
Quoted: 1226 Post(s)
14-17 fluctuations indicate normal work for the compressor. Don't recall which of the sensors show the outside temperature, but in hot weather the pressure should operate in 20's while high cut off switch is set about 32 bars.
Looks to me you are good or slightly low. What is the static pressure?
Kajtek1 is offline
post #3 of 25 (permalink) Old 11-29-2008, 10:04 AM Thread Starter
Sensor 2 would be the OT sensor.How do I check the static pressure and is the fan on and off OK? As an FYI, here are the other sensor designations
Sensor 1 - Inside Temperature:*
Sensor 2 - Outside Temperature:*
Sensor 3 - Left Heater Core Temperature:*
Sensor 4 - Right Heater Core Temperature:*
Sensor 5 - Evaporator Temperature:*
Sensor 6 - Engine Coolant Temperature:*
Sensor 7 - Refrigerant Pressure:*
Sensor 8 - Refrigerant Temperature:*
Thanks!
jchumba is offline
post #4 of 25 (permalink) Old 11-29-2008, 10:34 AM Thread Starter
With car temp set on 'Automatic' @ 72F, the compressor seems to kick every 15 seconds.
1. Is the 15 secd on and off too frequent or normal?
2. My cheap gauge from Autozone reads 'under 'Normal' pressure zone. The gauge is 0-100 setting, mine reads on approx on 30 reading. I think these are in PSI.
jchumba is offline
post #5 of 25 (permalink) Old 11-29-2008, 10:42 AM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 5 Post(s)
Your
total fill weight is on a label on top of the ecu cover or close to it.If you put in 34 oz. the system needs to be tested by a pro and the leak fixed.I sure hope you did not use 34 ounces of the stuff with the leak stuff crap in it
mb a/c system is variable on demand you could see changes while running of range 7-17 and it would be normal based on the demand and temperature.
Find the leak and repair it,before you kill the compressor.
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #6 of 25 (permalink) Old 11-29-2008, 10:56 AM Thread Starter
ECU unit reads 2,20 plus 0,07 lbs of R134 a. I belive that is what the system can hold. No sure how that related to teh 34 ounces I put in. Not sure what that means. The dealer had checked performed service A/B like a year ago and had adviced that I need to recharge the system.I didn't worry about it because the system was still cooling Ok and I was driving the car only only weekends not to mention I haven't driven it in 4 months!
Should I monitor any pressure drops/system performance before taking to a pro for 'leak check' or should I get immendiate check?
Thanks!
jchumba is offline
post #7 of 25 (permalink) Old 11-29-2008, 11:06 AM Thread Starter
Just to clarify, I did put genuine r134a refrigerant, not the stop leak stuff-I was keen on that due to previous advice.
jchumba is offline
post #8 of 25 (permalink) Old 11-29-2008, 02:22 PM
Date registered: Nov 2005
Vehicle: 1996 210.020
2.2 lbs is a total charge of 35.2 oz. Was the system completely empty before you started?
Matt L is offline
post #9 of 25 (permalink) Old 11-29-2008, 04:12 PM Thread Starter
The system was not empty as the compressor was kicking and cold air blowing though not as cold.
Prior to adding freon my system producing a hissing metallic sound that come on when AC was on-so I decided to address the problem. Did onboard diagnostics and sensor #7 showed 11 with car running. Decided to add some freon.
So I went to autozone and got some r134a with a test gauge. The system showed low on my test gauge, so I added a 19 oz r134a then took a reading and it showed full but on the lower side which is approx 30psi on my gauge. System behaved normal after the first can. So, I bought another 15oz and loaded. I ran onboard diagnostics and all error gone except E FF, bit sensor # 7 was varying between 13-17 and the compressor kep on coming over 7 seconds or so and fan was runnin g unusually high, so I got worried.
Solution? I let some freon go b reattaching hose(wrapped towel around the end of it so escapping freon does not spills out) and did the onboard diagnostics. Sensor #7 is now steady @ 14. Also the ac system is running normal(fac stopped kicking on and off and running high/loud).
Cold air seems to work well. No hissing sound. No loud fan.
Should I assume all is well!? and were my problems related to overcharging?
Wow if they system hold 35OZ, I assume it had approx 20OZ and I pumped 34 ounces. Possible ocercharge? please advice?
jchumba is offline
post #10 of 25 (permalink) Old 11-29-2008, 04:34 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 131 Post(s)
Yes and no..
Yes, you apprently did overfill, and you seem to have taken care of that immediate issue.
However, your system most likely has developed a small leak (which is where the R134 went away over time).
A R134 system is best maintained at full efficiency with a professional (but EZ) system evacuation and refill with all new. The evacuate all the old, hold at vacuum to check for leaks, then if the system shows intact they refill with all new R134 (by weight rather than pressure). Any competent auto air con shop can do this type of service. The full deal runs about $80 where I live, some other places higher some places a tad lower.
fabbrisd1 is offline
    hissing sound Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 10 04-16-2008 08:33 AM
    hissing sound SilverStar W126 S,SE,SEC,SEL,SD,SDL Class 11 09-19-2007 09:01 PM
    Aux fan run when Engine fan runs? Is it possible? Haroundb W123 E,CE,D,CD,TD,TE Class 48 07-22-2007 08:17 AM
    A/C hissing sound Sandro N W210 E-Class 2 11-26-2004 03:05 PM
    hissing sound AmoS500 W140 S-Class 1 07-01-2003 05:38 AM
