How to prevent windshield washer liquid from freezing - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 11-28-2008, 03:35 PM Thread Starter
Date registered: Mar 2008
Vehicle: 2001 E320 Wagon
I normal use the premixed windshield washer liquid for my car.
What should I use to prevent this washer liquid from freezing up in very cold weather?
yumling is offline
post #2 of 8 (permalink) Old 11-28-2008, 03:38 PM
Vehicle: Mercedes W210 E320 wagon
Just use winter type windshield fluid. .
Bansai is offline
post #3 of 8 (permalink) Old 11-28-2008, 05:40 PM
Kajtek1's Avatar
Quoted: 1223 Post(s)
That might be easy in VA, but supposable it is the law to sell 32F rated windshield fluid in CA, unless the mountain station is exposed to the snowstorm. Last year coming from skiing trip I stopped at 3 gas stations in the mountains and none did carry the 0F fluid. Than I dropped off friend at BP station in Martinez (just on the Pacheco exit off 680) and they had it.
I added it only once, but even without using sprayers the level in my reservoir dropped quite a bit. I believe that with heating system in Mercedes -the alcohol in the fluid evaporate very fast.
So I am keeping the second bottle of good stuff for real situation.
Kajtek1 is offline
post #4 of 8 (permalink) Old 11-29-2008, 05:56 AM
X72
Katjek1, do you have the Prestone de-icer booster that comes in a small bottle in your area. It is the second entry on this site Prestone :: Products : Windshield Washer Fluids
You could add that to any fluid you have in the car.
In the worst case, just add a quart of the 90% isopropyl alcohol available at any pharmacy or grocery store. Any alcohol added to water will depress the freezing point of the solution.
Addendum: The big truck stop chains like Flying J and Pilot usually sell the alcohol concentrate also.
X72 is offline
post #5 of 8 (permalink) Old 11-29-2008, 06:19 AM
In case when you have less then -20F outside then I would use any cheap, pure Vodka (or alcohol) as windshield fluid. I'm serious. It works great (tested in Russia).
Bansai is offline
post #6 of 8 (permalink) Old 11-29-2008, 07:12 AM
Date registered: Sep 2008
Vehicle: 2002 E430 4-Matic
Quoted: 33 Post(s)
I know a guy who winterizes his boat using Vodka in the FW system. He has a big party in the spring when he "clears" the system.
Figuero is offline
post #7 of 8 (permalink) Old 11-29-2008, 09:10 AM
Kajtek1's Avatar
That's something that is worthless without pictures
In the past, living in Poland where special fluid were not available I used denatured spirit added to the water what is equivalent of what guys suggest above.
One trick I learned hard way is that after adding the antifreeze you have to pump the new stuff thru the tubings and nozzle -meaning using the sprayers short time after adding new stuff.
Low freezing point in the reservoir does no good, when your nozzles are frozen.
Kajtek1 is offline
post #8 of 8 (permalink) Old 11-29-2008, 09:15 AM
Mark Cummins's Avatar
Vehicle: W211/W210 Estate /W209/W208
Quoted: 4 Post(s)
The heater runs lines inside the washer tank..once the engine temp is warm it will have warm washer fluid...
The Factory washer fluid will not freeze..buy a couple of tubes and add to the washer tank
Mark Cummins is offline
    windseild washer liquid. .. lifethrasher W220 S-Class 5 10-22-2008 05:00 AM
    Freezing Windshield Washer Nozzles jrehm W123 E,CE,D,CD,TD,TE Class 0 12-20-2004 07:18 AM
    1995 E320 -- freezing windshield sprayers MadManMikeAMG W124 E,CE,D,TD Class 2 01-13-2003 01:19 AM
    ML320E windshield wiper liquid not shooting out? Tabo W163 M-Class 9 01-29-2002 11:28 AM
    What's the best stuff to use to prevent smearing of water on the windshield during rain? T-bone R170 SLK-Class 13 02-27-2001 09:00 AM
