2000 E320 Trunk wont open HELP!! - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 11-23-2008, 08:02 AM Thread Starter
Date registered: Oct 2008
Hi,
All of a sudden my trunk wont open. Not by the key, center console switch, or the trunk button. No light on saying its open either. everything else works except the trunk. I will need to at least temporaraly get into the trunk so please let me know how to do it? I have the rear seat out and did not want to take off the battery cable in fear that my radio will need to be tended to. Can someone help? Thanks as usual.
Phil
phil1347 is offline
post #2 of 11 (permalink) Old 11-23-2008, 06:29 PM
IFS
IFS's Avatar
Date registered: May 2008
Vehicle: 00 E320 4MATIC
When u say not by the key, u meant remote key or "real" key.
I know that there's a valet key for the trunk when u giving your remote key to someone else, so your trunk cannot be opened in regular ways.
It might be someone locked your trunk with real key and it won't open now.
IFS is offline
post #3 of 11 (permalink) Old 11-23-2008, 07:14 PM Thread Starter
valet
You were right but i did not do it. Is there a way to do it with pushing a succession of buttons on key
Phil
phil1347 is offline
post #4 of 11 (permalink) Old 11-24-2008, 02:47 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Originally Posted by phil1347 View Post
You were right but i did not do it. Is there a way to do it with pushing a succession of buttons on key Phil
Not that I am aware of.
Musikmann is offline
post #5 of 11 (permalink) Old 04-10-2009, 05:46 PM
Date registered: Dec 2007
Vehicle: 1998 Mercedes Benz E320 Sedan
Send a message via AIM to EnduroE320
any updates to this situation? I'm in the same boat. I have the remote key but not the laser key that fits inside the remote. Trunk opened fine before and just yesterday it stopped. The light stays on (on the little knob) but when you push it nothing happens.
EnduroE320 is offline
post #6 of 11 (permalink) Old 04-10-2009, 06:26 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 123 Post(s)
Worst case, you get keys made with proof of ownership at the dealer... it's kindof rough going in thru the back seat.
fabbrisd1 is offline
post #7 of 11 (permalink) Old 04-10-2009, 08:21 PM
Kajtek1's Avatar
Quoted: 1168 Post(s)
If you lock the trunk with blade key (turn it all the way to the right and remove the blade flat side horizontal) the trunk will not open with electric switches unless the mechanical lock is unlock again. The valet key will not open the trunk, nor the glove compartment, because it is designed for the valets.
Kajtek1 is offline
post #8 of 11 (permalink) Old 04-14-2009, 10:34 AM
My battery had died when the car was locked. I had to unscrew the bolts from the actual hood latchs to get the hood open. (cars being repainted rite now and its easy to unlatch the hood with the headlights out) I got the hood open, Jumped the battery from the terminals in the engine bay, but the trunk still wont open.
Remote I have does NOT have the key in it. Just the bare remote. It worked before but now it wont!
post #9 of 11 (permalink) Old 04-14-2009, 11:49 AM
E430SportMB's Avatar
Vehicle: 2000 MB
With car unlocked, try inserting the small key on the trunk key slot and rotate it counter clock wise and push. It worked on mine a month ago.
I believe I think, so therefore, I think I believe !
E430SportMB is offline
post #10 of 11 (permalink) Old 04-14-2009, 05:40 PM
Vehicle: 2002 e320 4 Matic Wagon
Here is what i did when this happened to me a few weeks ago.
I just solved the problem. The problem with the trunk not opening was a box in the trunk,that was keeping it from opening .What my friend did is exchange the vacuum tube that operates the 4 doors and the gas cap, with the other vacuum tube opening the trunk. What he thought is the one for the doors has certainly more pressure than the one for the trunk.When he pressed the trunk button, the trunk opened right away.the vaccuum tubes are located beside the battery on the passenger side under the rear seat. If I remember well the tubes are yellow. Now I will have to take off my trunk keyhole barrell and try to find a locksmith to repair it if it can be done.Thanks everyone and Ohlord for the help.
Also please look this thread I had started. Good luck.
http://www.benzworld.org/forums/w210...n-anymore.html
Hi Fi is offline
    TRUNK WONT OPEN? Old Otto W210 E-Class 4 11-05-2008 01:33 PM
    Trunk wont open! platt-deutsch W220 S-Class 12 03-13-2008 02:07 PM
    Trunk wont open Chia pet W123 E,CE,D,CD,TD,TE Class 6 08-28-2007 06:41 PM
    trunk wont open. benz3000 W210 E-Class 3 04-19-2007 01:22 AM
    Rear Trunk wont open. NVDR C208/A208 CLK-Class 2 10-14-2005 12:03 PM
