Need Help!!! Serpentine belt came off my car!!! - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 11-01-2008, 05:42 PM Thread Starter
Date registered: Nov 2008
Vehicle: 99 E320 4matic
I have a 1999 e320 4matic with a big problem. I was driving back home today and check engine oil light when on. Then my power steering went out and the car started to smoke. so I pulled off the road and checked everything. The serpentine belt came off and there was oil everywhere. There was oil all over the floor. I honestly don't know why the serpentine belt came off??? The car has 72k and I never had any problems with it until now. Has anyone have this problem before? I think The engine was overheated and blew the head gasket. I am not sure though because it is dark out now and the car is still at the location. If anyone can me help please do!!!
holyvirsago is offline
post #2 of 14 (permalink) Old 11-01-2008, 05:54 PM
Kajtek1's Avatar
Quoted: 1289 Post(s)
Welcome to the forum and sorry about the circumstances.
While I can't take a look under the hood, I can say that overheating is not likely. You would see red warning before and supposable the computer would kill the engine before heat might damage it.
My very remote guess is, that something broke on your engine (power steering pump?) and that is what cost the belt to come off.
Keep us posted and good luck.
Kajtek1 is online now
post #3 of 14 (permalink) Old 11-01-2008, 06:06 PM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 6 Post(s)
Something
seized up.Had the harmonic balancer recall ever been performed?
Get a flashlight and look down at the front lower part of the engine,where the main pulley is located.Is it all cattywhompas and torn into the oil pan? Their in lies your massive oil leak.If you have it towed home follow the procedure for towing a 4matic in your owners manual or have it loaded on a flat bed.You need not add insult to injury
ohlord
sorry
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #4 of 14 (permalink) Old 11-02-2008, 06:06 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
The belt came off because it was covered in oil.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #5 of 14 (permalink) Old 11-02-2008, 09:36 AM
Mark Cummins's Avatar
Vehicle: W211/W210 Estate /W209/W208
Quoted: 4 Post(s)
I Would also inspect the crank pulley as they are a known problem to separate and the outer ring of the H/B will grind up the front cover of the engine block and cause a oil leak..Then the belt comes off..as the mono belt will NOT come off due to oil on it..Thats what the belt tensioner does..Keep the belt tight
Done a couple of them...
MB has changed the part number on them..make sure you get the latest one!
Mark Cummins is offline
post #6 of 14 (permalink) Old 11-03-2008, 02:06 AM Thread Starter
Thank you for the reply, I will take a look at the pump, my guess is also the tension pulley. Well i thank you and will keep posting
post #7 of 14 (permalink) Old 11-03-2008, 02:13 AM Thread Starter
Thanks for replying,
the tensioner was my next guess, maybe it was a little loose who knows. Thanks for the info on the oil leak.
post #8 of 14 (permalink) Old 11-03-2008, 02:16 AM Thread Starter
ohlord
sorry
I don't think the harmonic balancer recall has been performed although i need to look at it. And I did got it towed home and put on a flat bed. Thanks for your reply ohlord
post #9 of 14 (permalink) Old 11-03-2008, 04:47 AM
RichardM98's Avatar
Date registered: Oct 2007
Vehicle: 1998 E320 Wagon
Quoted: 26 Post(s)
...Then the belt comes off..as the mono belt will NOT come off due to oil on it..Thats what the belt tensioner does..Keep the belt tight...
I have to agree with Kent. The belt has ridges which engage grooves on the accessory pulleys EXCEPT on the tensioner where the back of the belt (smooth) rides on the smooth pulley. A little oil and I think off it jumps!
RichardM98 is offline
post #10 of 14 (permalink) Old 11-03-2008, 09:09 AM
ohlord's Avatar
Quoted: 6 Post(s)
Smoke
oil everywhere,oil on the floor,is not a jumped belt from a little oil on the belt.The oil got there somehow and it either was a catastrophic failure or someone change the oil and failed to tighten the oil filter cap and the oil purged itself
He will find out soon enough.I hope it is the latter,and not the HB.
a Mercedes Benz"
ohlord
ohlord is offline
"V Belt" as MB calls it or Serpentine Belt 98MBE320 W210 E-Class 12 01-05-2010 02:36 PM
Serpentine Belt Alan (Chicago) R170 SLK-Class 6 06-12-2007 08:22 PM
serpentine belt pauljc W126 S,SE,SEC,SEL,SD,SDL Class 1 11-18-2005 05:31 AM
SERPENTINE BELT - what is? lnguyenh R129 SL-Class 5 04-25-2005 02:07 PM
Serpentine Belt bdonkersgoed W140 S-Class 7 06-01-2004 06:32 AM
