EGR Valve question (P0400) - Page 2 - Mercedes-Benz Forum
post #11 of 57 (permalink) Old 12-16-2009, 06:24 PM Thread Starter
Vehicle: Mercedes W210 E320 wagon
Originally Posted by ohlord View Post
using my method that requires no removal of the tube or the egr on the m112 and m113 engines.You most likely did not gert it all cleaned out last time.
ohlord, are you talking about can of seafoam in gas tank?
Bansai is offline
post #12 of 57 (permalink) Old 12-17-2009, 07:42 AM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 5 Post(s)
No
pm me
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #13 of 57 (permalink) Old 12-18-2009, 08:16 AM Thread Starter
Just removed ERG valve. The pipe is clean! I guess that I have to replace EGR valve itself.
Bansai is offline
post #14 of 57 (permalink) Old 12-18-2009, 08:46 AM
ohlord's Avatar
Quoted: 5 Post(s)
Why you did not wait
and call is beyond me.However since you have decided to make it harder and more labor intensive clean the tube and the inlet to the intake before you clean the egr valve. You have a flow problem not an egr failure code. Test the valve before replacing since it most likely it is fine.You are throwing money at a problem that could have been solved in 15 minutes without pulling anything.
The time some people go to take the long way around a solution always amazes me.But hey it's their time
a Mercedes Benz"
ohlord
ohlord is offline
post #15 of 57 (permalink) Old 12-18-2009, 03:30 PM Thread Starter
ohlord, old valve was stock. Because corrosion. I tried to clean it up by Seafoam. But event after that new one works smoother.
These are parts, which I replaced today:
A1121400460 — EGR valve
A1121590080 — intake pipe gasket.
A1121412180 — EGR pipe gasket
A1121412180 — EGR valve gasket.
A1120180482 — vent pipe.
Bansai is offline
post #16 of 57 (permalink) Old 12-18-2009, 07:34 PM
ohlord's Avatar
Quoted: 5 Post(s)
I suppose that
is a viable $200 solution to a 9 buck problem.Or did you get the parts at the dealer and spend more?
a Mercedes Benz"
ohlord
ohlord is offline
post #17 of 57 (permalink) Old 12-18-2009, 07:41 PM Thread Starter
$120 for all of them . ohlord, could you please describe what shall I have to do with this issue for $9?
Bansai is offline
post #18 of 57 (permalink) Old 12-18-2009, 07:50 PM
ohlord's Avatar
Quoted: 5 Post(s)
$120 for
all of them? What did you get fakebays? Used? Or steal them
Drill,bolt,crc mass air cleaner,old speedometer wire,15 minutes.
a Mercedes Benz"
ohlord
ohlord is offline
post #19 of 57 (permalink) Old 12-19-2009, 05:17 AM Thread Starter
I bough those parts locally. At local MB Shop. . parts.com has better price, but I didn't want to wait three, five days.
Bansai is offline
post #20 of 57 (permalink) Old 01-01-2010, 03:31 PM Thread Starter
I cleaned both covers. Found that EGR holes in covers have different diameters.
Driver side covers (with oil cap) has 1.5mm hole. Small cover on left side has hole with diameter ~1mm.
Both holes were clogged when I removed the covers.
Bansai is offline
  • Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
    EGR Malfunction - Code P0400 UncAl W163 M-Class 11 03-31-2017 01:21 PM
    EGR VALVE P0400 Diagnostic tool elomont W163 M-Class 2 05-02-2007 12:50 PM
    C280 P0400 EGR Malfunction Dennis78 W202 C-Class 2 04-07-2007 12:43 AM
    quick egr valve question andrew_falky W126 S,SE,SEC,SEL,SD,SDL Class 3 07-10-2005 09:02 PM
    P0400 EGR Flow Malfunction cure - See photos ScubaDriver W163 M-Class 3 12-23-2004 05:07 PM
