PO 410 code - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-05-2008, 04:18 PM Thread Starter
Date registered: Oct 2008
PO 410 code
I have a 1998 e320 that I just bought about a month ago. I changed the plugs, wires, fuel filter, cabin air filter, serpentine belt, air filter, oil change, tranny fluid change, thermostat, antifreeze and rear diff. fluid. Used oem mercedes parts. It has 206,000 miles on it and still runs like new. I did all of the service myself just for preventative maintenence. I know have a po410 code. I changed the air pump switchover valve. Didnt change the air pump yet. Want to know what else it could be if I change the air pump and the code comes back?
benz w210 is offline
post #2 of 2 (permalink) Old 10-05-2008, 04:51 PM
Vehicle: '98 E430
Check the secondary air injection valves to make sure they function freely then try putting voltage across the air pump with the wiring disconnected. Either a stuck shutoff valve or dead air pump will bring up an 0410 code. If the air pump is dead, check the internal wiring connections to make sure they are still connected. The ones on my air pump had come loose. Simple fix to resolder.
NOLA430 is offline
asr code 30 and efp code 15 mydreambenz W140 S-Class 7 05-12-2011 03:40 PM
Does the Audio 20 have a radio code? - NOT a code request!! TomTanderson Audio & Telematics Forum 2 02-09-2008 02:00 AM
PO442 code caused buy a PO455 w/o code ? gw17625410 General Mercedes-Benz 3 06-14-2007 12:06 PM
Body Code? Equipment Code? Leeyore W123 E,CE,D,CD,TD,TE Class 4 07-19-2006 10:13 PM
SLK55 - 410 BHP version? teen_runner19 R171 SLK-Class 4 08-19-2004 10:12 AM
