Old 09-30-2008, 07:22 PM   #1 (permalink)
Date registered: Jul 2007
Vehicle: 2008 GL320CDI, 1999 E320 Wagon 4Matic
Water in door
After recent heavy rains, water has accumulated in the driver's rear door on my 1999 E320 wagon. The water sloshes back and forth when accelerating and braking. Are there drain plugs or does the inside panel need to be removed?
dpallone is offline   Reply With Quote
Old 09-30-2008, 07:41 PM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
There has to be drains, since all car doors leak some water in at the window. I don't know where they are, other than to say, "At the bottom."
You can clean the drains out with some wire or weed-whip line or something similar and that may be enough. If it were my car, I would be tempted to take the door panel off and clean it up inside, but I probably would not do it.
Old 09-30-2008, 08:11 PM   #3 (permalink)
ohlord's Avatar
Drain holes
at bottom of door.
Get the panel off and get it dried and wd40 and the holes cleaned out before you return to talk about the rust in your rear door.
Rear Door
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz
My friends all drive Porsches
I must make amends
Worked hard all my lifetime
no help from my friends
So Lord, won't you buy me
a Mercedes Benz"
That's it
"The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over."
ohlord
water getting into door andrew_falky W126 S,SE,SEC,SEL,SD,SDL Class 5 06-05-2008 11:57 AM
water in driver's door dpallone W210 E-Class 4 02-15-2008 09:13 AM
Water gets into the rear door when rains! bulahee W201 190E, D-Class 4 02-28-2006 03:12 PM
Water leak front door speaker grills cigator R129 SL Class 3 01-28-2005 06:52 AM
Has NE1 put a door protective strip along the vertical edge of the door? DaveS R170 SLK Class 0 06-22-2003 01:00 PM
