Transmission Gear shift won't shift from D to low (4,3,2 or 1)
I cannot get the shifter to move from D to 4 and down through 1 from there. It was working fine until recently. I believe my sunglass arm got in there and may have caused some damage. Any ideas on what may be wrong and what i could look at to diagnose or repair. The tranny works fine otherwise- moves smoothly through gears. I just cannot manually put it into low gear.
prnd are all mechanical accuatuated via the shift linkage,manual mode is electroic.Something may have fallen into the shift module that is blocking the disengagement process between both functions.Have you popped off the console wood and examined the trans module for something in the way?
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz
My friends all drive Porsches
I must make amends
Worked hard all my lifetime
no help from my friends
So Lord, won't you buy me
a Mercedes Benz"
That's it
"The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over."
ohlord
Thanks for the info. I had pulled the console wood up and hadn't seen anything in the way. Although I hadn't tried to disassemble the shift module as I wasn't sure exactly how to pop it open. I'll take another look at it this weekend. Do you have a good link to take it apart to the shift module?
