Old 09-26-2008, 12:08 PM   #1 (permalink)
Date registered: Aug 2007
Vehicle: 1998 E320 4matic wagon
downshift clunk
I feel a bit of a clunk when you take your foot completly off the gas slow to about 5-15 MPH then a second later slowly take off. the trans fluid is only a few thousand miles old, flex disk looks good on visual, any ideas?
1988 300TE wagon, 1998 E320 wagon, someday 2008 E350 wagon, .....
korbenz is offline   Reply With Quote
Old 09-26-2008, 02:47 PM   #2 (permalink)
ohlord's Avatar
Changed
the rear diff fluid?
it gets old and tired also
check your motor mounts.
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz
My friends all drive Porsches
I must make amends
Worked hard all my lifetime
no help from my friends
So Lord, won't you buy me
a Mercedes Benz"
That's it
"The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over."
ohlord
Old 09-27-2008, 07:17 AM   #3 (permalink)
Franasia's Avatar
Date registered: Jan 2005
Vehicle: 2000 E320S4 210.282
Panetary Gearset
I’ve been experiencing this problem ever since I bought my 4Matic almost three years ago.
Clunk occurs when the car downshifts into first gear as you're rolling to a stop. I found that by switching transmission program into W mode permanently helps a lot. You don’t get to hear the clunk that often.
There are a few threads on the forums on the topic but for some reason word never spread out as to the cause and fix of the problem, which has been posted only a couple of times without any major public reaction. See:
http://www.benzworld.org/forums/w210...-e320-awd.html
4MATIC System - Smoothness of Shifting - MBWorld.org Forums
This is the fix:
Slack in the planetary gearset: the recommended repair under TSB AF28_10-U-1600AG is to replace the planetary gearset with a friction plate.
Hope it helps.
Cheers.
“Design embodies the values of a company. Even if there were no star, the car must always be recognizable as a Mercedes-Benz.” Peter Pfeiffer, Daimler AG
Franasia is offline   Reply With Quote
Old 09-27-2008, 01:05 PM   #4 (permalink)
Musikmann's Avatar
All I remember seeing, at least in recent memory, is that gregs210 said it is a horrible job.
Old 09-27-2008, 07:03 PM   #5 (permalink)
that (planetary gear work) won't be done on this car
I've decided to be very careful about spending too much on this wagon.
I just ran into more corrosion underneath than I thought when I changed the D oil this afternoon. Hopefully the Diff oil change at least helps maintain the current condition, which I can live with.
In the last three months I've spent about $3K on tires, shocks, control arm bushings, 4wheel alignment, CV boot, ball joints, extra key, windshield, blower motor, filters, etc...
But you know how it is when the car has 120K and you start fixing things, it's easy to just keep going.
Now, other than the occasional clunk and corrosion, the car runs very nice and tight, still gets great MPG. I hope to get another 2-3 years out of it then move on.
Old 10-04-2008, 08:16 PM   #6 (permalink)
changed the diff oil one week ago and wanted to give it a fair test.
It came out very dark, but nothing to unusual looking
I don't notice any of the clunk sounds or feel nearly as much. it's very smooth.
For anyone else with this issue that's the first place to start.
I don't know what the spec is on replacement, my wagon has 120K and it definetly needed changing.
Old 10-04-2008, 08:38 PM   #7 (permalink)
suicidal4life's Avatar
Vehicle: 2001 E430
My car did this when the engine mounts were failing. After replacing them the clunk stopped. You might want to check and see if they have been leaking.
Mods•Kleemann headersMetal'cats355/328 Brembo BBK19" Carlsson 1/6Carlsson pedals"Carlsoon" lighted sills&shifterH&R cupkitspeedybenzburlwood steering wheel&door pullswave LED tailsSprintbooster
Countermeasures•Valentine1 etched in rearview mirrorLaser Interceptor
Awaiting install•Stiegemeier ported HPS gen1 SCSLR camsCoolingmistWald EX bodykitKmacVRP intake spacersEisenmann raceQuaifeEvosport pulleysCarlsson emblemsOE xenon'sextra heads&intake for port/polish project
suicidal4life is offline   Reply With Quote
Old 10-24-2008, 01:40 PM   #8 (permalink)
Date registered: Sep 2004
Vehicle: 99' e320w 4matic
Clunking
I had a similar issue and my indie said it was the rear Diff. and to just check fluid twice a year...... It would always clunk a bit at certain times. THEN, car suddenly lost drive to the wheels, loud clack,clack,clack,clack under feet. slowed to a stop, put it in park, it kept rolling.... figuring a tran. issue..... local guy sent car to transmission house for a used w/ 1 year warranty for 3500 big ones. not bad as car has 210k and no major repairs yet ! Luckily, tranny guy found front wheel drive U-Joint let go. had to wait for part to check tranny, then sent car back not needing tranny, only u-joint... $800. not $3500. Nice to know my guy is honest, most would replace tranny anyway to get the cash......... So, U-joint was causing the clunk and my other very good indie missed it !
Check the front wheel drive U-Joint !!!!!!!!
carver is offline   Reply With Quote
C220 won't downshift Chubbs103 W202 C-Class 3 07-21-2008 07:34 PM
Downshift to First!!! Any ideas? ChopTop250SE W126 S,SE,SEC,SEL,SD,SDL Class 14 03-07-2007 05:10 AM
Transmission downshift goingonabenzer W210 E50 AMG, E55 AMG 4 10-03-2006 03:23 PM
Optimal downshift beppo98 R171 SLK Class 4 05-04-2006 10:54 AM
When do you use downshift? Benz Devil W126 S,SE,SEC,SEL,SD,SDL Class 13 11-27-2005 01:20 AM
