Stall at traffic light - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-19-2008, 08:36 AM Thread Starter
dr.pitch's Avatar
Date registered: Sep 2002
Vehicle: 00 E320S4, 89 Porsche 911 Cab, 86 Volvo 764TA, 78 Euro 300D 4MT
This morning on the commute by car died suddenly sitting in a turn lane. didn't sputter, just turned off. I tried restarting for about 5 minutes while drivers around me got pissy (rightfully, it was rush hour). All lights on (except CEL!), cranked fine. then after 5 minutes it started right up and I drove off. First time this has happened.
After scanning the forum, looks like CPS is likely culprit, relatively easy DIY and only $56 on autohaus.
my question is: what is the likelihood this is something OTHER than the CPS? Should I go ahead and order it or should I take it to the shop (or call my mechanic) for diagnosis?
dr.pitch is offline
post #2 of 6 (permalink) Old 09-19-2008, 09:28 AM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 5 Post(s)
Cps
it will keep doing it more as time goes on.
r/r in the diy also on *****************
ohlord
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #3 of 6 (permalink) Old 09-19-2008, 09:58 AM
Kajtek1's Avatar
Quoted: 1167 Post(s)
Bad part is that there is no CPS testing possible, unless you have laboratory equipment.
Good part is, that CPS cost less than $100 and is less than 1 HR job.
Kajtek1 is online now
post #4 of 6 (permalink) Old 09-19-2008, 05:24 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Plus 3. On those symptoms you'd be hard pressed to find someone familiar with these cars that would suggest anything besides the CPS, unless of course they have a boat payment due and you have a particularly gullible look.
But ONE HOUR to do this job? I did it in 15 minutes in the parking lot at work...and that includes the time it took to take some pictures. Hardest part is that it's largely a "by touch" job and you don't want to drop the screw that holds it in. If you can change a spark plug you can do this job; ohlord talked a single mom and her son through it. Just reference the primary DIY as well as the one I did about making it easier to locate, they are both in the DIY sticky. If you want to branch out from the seemingly-buggy bosch, diyautoparts.com sells the Hella brand, or at least they used to. I found that after I'd already ordered a bosch, would have gone that way if I'd known. In any event, don't source it from an unknown supplier, such as ebay. You're likely to get a good price on a used and cleaned up unit or a cheap knock-off.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #5 of 6 (permalink) Old 09-19-2008, 05:50 PM
ohlord's Avatar
Quoted: 5 Post(s)
Actually
I talked her through it,and she had her son climb in while she talked him through it
both were very happy
ohlord
a Mercedes Benz"
ohlord
ohlord is offline
post #6 of 6 (permalink) Old 09-21-2008, 06:02 PM Thread Starter
dr.pitch's Avatar
was still holding out that it was a "fluke"
drove the car yesterday, got stranded three times (!). yeah I'm not too bright sometimes.
First time, happened while driving, pulled over, sat 90 sec, started, drove off.
Second time happened at 4 way intersection, pushed the car to nearby parking lot. shopped for awhile, didn't start, went for coffee, came back. started (after about 2h cooldown). drove another 2 miles and stalled at another busy intersection. pushed to the gas station, got towed home (flatbed).
while waiting for the tow truck, got out my code reader, told me CPS was bad. so I went from 99% sure to 100%.
I have ordered the Bosch from autohaus - I have the one clip model which I didn't see in Hella at diyautoparts. I will need to get a torx socket as I can feel I have the external type.
Greg is correct again. Thanks for the previous posts and helpful photos - I went right to it and hopefully will have no problem installing the new one.
Even though it's a $60 part instead of a $10K blown engine, doesn't take away the embarrassment of being stranded in an intersection. People zoom by in clunkers and give you sneers because your German engineering is kaputt.
dr.pitch is offline
    190E 2.6 don't pick up higher than 2000 RPMs from traffic light Felix123 W201 190-Class 0 04-25-2008 02:27 PM
    Saw a Daewoo at the traffic light today... mclasser Off-Topic 3 03-21-2008 02:16 PM
    Traffic light timers Corkscrew General Mercedes-Benz 6 06-25-2006 09:07 PM
    Stopping at a traffic light ekhalil W163 M-Class 3 12-11-2003 06:39 AM
    I was opening the roof at a traffic light today and ... i was 5 seconds short! Had to start moving RLO -- Vancouver R170 SLK-Class 8 07-16-2002 11:31 PM
