wagon with what looks like hydraulic fluid leaking - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 08-29-2008, 03:49 PM Thread Starter
Date registered: Aug 2007
Vehicle: 1998 E320 4matic wagon
just slightly in front and to the inside of the front left tire I'm seeing drops on the garage floor, looks like Hydraulic fluid so I cleaned the area around the washer tank and hydraulic tank to look for obvious leaks. nothing yet anyone delt with a similar leak? The tank was down at the min level and I filled it to the max line and have been monitoring.
1988 300TE wagon, 1998 E320 wagon, someday 2008 E350 wagon, .....
korbenz is offline
post #2 of 7 (permalink) Old 08-29-2008, 03:57 PM
Mark Cummins's Avatar
Vehicle: W211/W210 Estate /W209/W208
Quoted: 4 Post(s)
Inspect the power steering lines and the rack assy for leaks..seen a few racks leaking on the W210 Wagons
Peel back the boots on the rack to see if the seals are leaking as the boots will be filled up with fluid
Mark Cummins is offline
post #3 of 7 (permalink) Old 08-29-2008, 04:18 PM
RichardM98's Avatar
Date registered: Oct 2007
Vehicle: 1998 E320 Wagon
Quoted: 26 Post(s)
Start by removing your sound proofing panels since the fluid tends to travel and drop off away from the actual leak.
Clean the underside cross members, lines, oil sump and anything else which is oily. If the leak has been going on for some time you may need to do this twice.
I had a small leak which I thought was from the hydraulic system/PS system. I thought it was that system because the level in the reservoir flucuated.
Turned out the leak was from the gasket sealing the breather cover to the left valve cover. Others have had a leak from the base of the oil fill tube which is also located in that cover.
Good luck.
RichardM98 is offline
post #4 of 7 (permalink) Old 08-30-2008, 12:28 AM
Date registered: Mar 2008
Vehicle: 2001 E320 Wagon
I have a hydraulic oil leak on the left front pretty much directly at the bottom from where the hydraulic oil reservoir is located. There is a stain where I park.
Are these hydraulic reservoirs known to leak?
I also have a leaking left rear strut.
My suspicion is these many owners and non MB shops are not familiar with the self leveling suspension and as such that reservoir might be filled with ATF, power steering fluid, brake fluid or even windshield washer fluid.
This might eventually leaking to leaking seals in the hydraulic system. As such it would be wise to flush out the system when buying a used wagon.
yumling is offline
post #5 of 7 (permalink) Old 08-30-2008, 02:21 PM Thread Starter
starting to think compressor oil
the top of the compressor is hard to see and it sits right below the power steering pump but it looks like the oil is coming from the compressor. The oil color is clear so it's not motor oil.
AC still runs pretty good. Compressor presure on #7 of diagnostic is now 14 and a couple months ago I remember it being 16
korbenz is offline
post #6 of 7 (permalink) Old 08-30-2008, 03:32 PM
Date registered: Nov 2005
Vehicle: 1996 210.020
Is your power-steering fluid clear? Mine is.
If you are leaving puddles of compressor oil on the ground, your AC won't be working. Oil never leaks out by itself.
Matt L is offline
post #7 of 7 (permalink) Old 08-30-2008, 04:11 PM Thread Starter
my hydraulic oil is clear also
looks like the drips are coming from either the compressor or just above.
the oil looks like the same consistancy as the hydraulic. does this typically indicate the power steering pump itself? It's hard to see, but from above everything looks dry.
korbenz is offline
    1991 560SEL: Do I have to fix the hydraulic fluid leaking / suspension problem mukarram2000 W126 S,SE,SEC,SEL,SD,SDL Class 38 04-19-2009 06:55 PM
    Roof lock cylinder leaking hydraulic fluid wilko R170 SLK-Class 28 08-29-2008 05:28 PM
    Help! hydraulic fluid leaking from rear cylinders of 1991 TBDevilRay R129 SL-Class 1 08-10-2008 03:44 PM
    Lowered my 1997 SL600 , now it's leaking hydraulic fluid... BadassDmax R129 SL-Class 22 07-21-2008 05:20 AM
    Hydraulic Fluid for wagon yumling W210 E-Class 4 04-01-2008 11:46 AM
