Old 08-11-2008, 03:03 PM   #1 (permalink)
DimitriKatsaros's Avatar
Date registered: Jun 2008
Question Washer reservoir and pump replacement questions
Hey all,
I have a '99 E430 and need to replace the reservoir the pump, and a bunch of grommets and plugs for the windshield washer. Two questions regarding the process:
1. In order to replace the grommets surrounding the heater element, it looks like I'll need to remove the hoses going to it. However, I am concerned that I might screw things up by letting air in or spilling whatever is inside the tubes leading to the element out. Is this safe to do or do I need to take precautions?
2. Dunno how to remove the electrical plug going to the pump without breaking some clips... is there some trick to removal?
Thanks
Dimitri Katsaros
DimitriKatsaros is offline   Reply With Quote
Old 08-11-2008, 03:08 PM   #2 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
I was able to pull the pump out without removing the wires.
You are picky about heater grommets, aren't you?
Don't worry about air entering the lines. Just release the coolant cap to let the pressure out. The hoses are on the top level, so shouldn't have any leak.
Kajtek1 is offline   Reply With Quote
Old 08-11-2008, 03:09 PM   #3 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Loosen the coolant pressure cap prior to removing the coolant hoses from the tank heater. They're up high so you won't lose much coolant before you plug the lines. I don't think you need to worry about getting a bit of air in there, but you can purge the air when you reassemble with the new tank.
The connector to the pump on my '96 simply pushed up to remove. It was a bit sticky from being on there for years. I used a small flat-bladed screwdriver to help get it started.
Old 08-11-2008, 11:45 PM   #4 (permalink)
Smile Thanks for the responses!
Thanks... being that this is my first time with such systems, how do you purge the air?
Oh! I thought there was a locking tab that had to be gently pulled. Is that not the case? (Kajtek1... I am also replacing the pump with a new one, so I do need to disconnect the plug)
[quote=Kajtek1;3008848] You are picky about heater grommets, aren't you?
Yeah, well. they are looking a bit mungy, so all the grommets are going! :-) I want it to look its best.
Coolant cap as in the cap on the radiator's reservoir?
Thanks to you both
Dimitri
Mould in the washer reservoir 420 SE W126 S,SE,SEC,SEL,SD,SDL Class 4 08-13-2007 11:42 PM
Winds..washer Reservoir!!!!!!!! HighRoller W210 E-Class 2 02-06-2007 07:07 PM
Winshield Washer Reservoir DCCLK W208 CLK Class 11 10-26-2005 09:11 AM
Windshield Washer Reservoir Cap Replacement BDML430 W163 M-Class 1 01-16-2005 12:05 AM
windshield washer reservoir Chris Krikorian W163 M-Class 11 01-27-2002 12:57 AM
