Old 08-09-2008, 03:38 PM   #1 (permalink)
Date registered: Oct 2005
Vehicle: '99 E300TD & '03 E500 Sport
Send a message via AIM to swich2mac
99 E300 vibrations (slight shimmy) at 70-80mph
Hey guys,
I just picked up another 99 E300 (had one a few years ago) and had a question with regards to a very slight shimmy or vibration when I hit between70-80mph. When I am under acceleration, coasting, or steady cruise on a flat surface, I get a slight shimmy for about 5-10 seconds then it mellows out perfectly. About another 20-30 seconds of smooth riding, then vibration will kick in for another 5-10 seconds. I feel it in the driver seat, the steering wheel, and I can watch the empty passenger's seat head restrain shake like a leaf! This issue happens over and over between that speed range. If I am under 70mph, I am golden!
Could this be as basic as needing a good 4-wheel alignment, tire rotation, and balance? The car has brand new Michelin MXV4's, which I had on my last E300 and these are fantastic tires. I don't believe it is the motor mounts as they were replaced last year. I had to replace the mounts in my last car, which shook like hell all the time until they were replaced! Anyone with some advice to give until I can take my car into the MB dealer next week?
Thanks,
Scott
swich2mac is offline   Reply With Quote
Old 08-10-2008, 09:05 PM   #2 (permalink)
Anyone?
Old 08-10-2008, 09:28 PM   #3 (permalink)
Date registered: Jul 2008
hey buddy, I once had an issue where my steering wheel would noticeably shake between 60-70mph, as well as noticeable vibrations through the seat and forget about looking out the rear view mirror! Turned out the gas station i used to pump up my tires was spraying water with its air! I had a good amount of water in my tires causing a major imbalance headache. I'd definitely start with a balance/rotate (if you don't have staggered wheels that is!). The alignment won't change a thing. You don't need an alignment unless your car is pulling to one side or another. Get the tires balanced. If you put the car in neutral and rev up the motor do you feel any vibrations? if the answer is no then that should eliminate your trans/engine mounts from the picture. Only other real option would be a driveshaft imbalance/bend but this is improbable if you haven't damaged/ran over/hit anything.
Balance/rotate the tires and check back!
livegood is offline   Reply With Quote
Old 08-11-2008, 08:23 AM   #4 (permalink)
Thanks. I am going to take it to the MB dealer today.
Old 08-11-2008, 05:43 PM   #5 (permalink)
UPDATE: OK, my issue has been resolved. Come to find out, I had 2 brand new Michelin's on the rear and 2 worn (2/32) Michelin's on the front. After removing the worn tires, installing the new, a force balance on the front, and balance at the rear, I am golden! No more shimmy or vibes!
Vibration between 65 & 80mph Benz Newbie W220 S-Class 5 06-12-2008 02:54 PM
Vibrations '05 E500 4matic 80mph kirill1 W211 E-Class 5 06-19-2007 07:48 PM
Will 1996 E300 wheels fit 1992 E300? ptshark The Discount Tire Direct Tire, Wheel, Brake & Suspension 4 05-15-2006 09:35 PM
1999 E300 TD vibrations nkhimani W210 E-Class 1 10-20-2004 04:32 PM
unstable at 80mph ShollyC220 W202 C-Class 0 09-29-2004 05:40 PM
