Old 08-07-2008, 12:41 PM   #1 (permalink)
Texas320's Avatar
Date registered: Jul 2008
Driver's Seat won't move back
Drivers seat won't move back when using door controls. If the memory button is used it moves back wards no problem. Appears to be the swith on door . Not sure how difficult to fix or if any one has had this problem.
99 E 320 4Matic
Thanks,
Ken
Texas320 is offline   Reply With Quote
Old 08-07-2008, 12:47 PM   #2 (permalink)
Musikmann's Avatar
I have read some posts about similar problems and the door switch, you might find them using the search function. Also check out the DIY stickys at the top of the forum's 1st page.
Old 08-07-2008, 02:27 PM   #3 (permalink)
mercedes benz e320's Avatar
Date registered: Aug 2008
Vehicle: 2000 Mercedes Benz E320 4matic
u can try checking your fuses
mercedes benz e320 is offline   Reply With Quote
Old 08-07-2008, 02:35 PM   #4 (permalink)
MFK
Date registered: Jan 2008
Vehicle: E200 Kompressor 2001
Take the switch off and give it a good clean with electrical cleaner - may just be dirty contacts. Worth a try anyway.
Do check fuses before stripping door down just in case it is anything simple.
Good luck
MFK
MFK is offline   Reply With Quote
Old 08-07-2008, 03:16 PM   #5 (permalink)
JRS
Vehicle: 1997 E420
This happened to me, and if I recall correctly, I had to move the seat all the way forward, which reset the seat switch. Maybe someone can verify this.
JRS is offline   Reply With Quote
Old 08-07-2008, 04:14 PM   #6 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
consider this ..... which may be one of the probably causes, yet to be determined
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Old 08-07-2008, 07:39 PM   #7 (permalink)
Texas320's Avatar
Thanks for the responses.
JRS moving the seat all the way up was the ticket. Figured I would start with the easy one first.
Thanks,
Ken
Old 08-09-2008, 12:22 AM   #8 (permalink)
meooem1's Avatar
Date registered: Nov 2006
Vehicle: 99 e320 wagon gold/tan 96K miles
just want to add to this post in case someone actually does a search instead of opening a new thread. when i first bought my sedan in 2002, i thought that the car just did not have that much leg room. i did some research and found out that the tracks of the seat have some sort of safety sensor so fingers don;t get stuck in there. there was a lot of lube in the tracks and it must trigger the mechanism. every onece and a while the seat would not go back and i would have to get a paper towel and wipe the tracks, then the seat would go back. i guess i should have married a much taller woman...5'07" i'm 6'04". hope this helps someone down the line.
meooem1 is offline   Reply With Quote
Old 08-09-2008, 06:20 AM   #9 (permalink)
Musikmann's Avatar
Originally Posted by Texas320 View Post
Thanks for the responses. JRS moving the seat all the way up was the ticket. Figured I would start with the easy one first.
Thanks, Ken
Mine wasn't very helpful, but you're welcome. I'm glad you found such an easy fix with the JRS tip.
Passngr seat doesn't move fwd when u lift it up to get in the back seat :( Camsky W208 CLK Class 3 03-27-2008 03:55 PM
Driver's seat will not go back jbowen1094 W208 CLK Class 6 02-19-2008 12:30 PM
Driver's Seat Wont Move << Back -- advice needed. threequarters W201 190E, D-Class 7 12-11-2007 03:18 PM
Seat won't move back ??? xman W210 E50 AMG, E55 AMG 0 01-16-2007 06:03 PM
Move the seat back, Waaaaayyyyy back TimsSLK350 R171 SLK Class 1 11-04-2005 02:24 AM
