Old 08-07-2008, 11:51 AM   #1 (permalink)
Date registered: Nov 2005
Vehicle: '99 E320
are camber bolts a diy?
car is lowered with Biltstiens and Vogland springs. After 3000 miles I see the fronts are wearing on the inside. I have 1 1/2 degrees neg camber on the fronts. Are the bolts a diy project? They look it to me. thanks '99 210 sedan
'99 E320 black
'87 Grand National 1 owner
sixbangr is offline   Reply With Quote
Old 08-07-2008, 01:29 PM   #2 (permalink)
reyna7's Avatar
Vehicle: 2000 E430 Sport
Yeah - it should be a DIY job. At least I hope so because I'm going to be doing it this weekend. I bought mine from Autohauz. After that I'll just take it to the dealership for an alignment.
reyna7 is offline   Reply With Quote
Old 08-10-2008, 09:19 AM   #3 (permalink)
Vehicle: '99 E320
reyna
how did the bolt change go?
Old 08-11-2008, 09:37 AM   #4 (permalink)
reyna7's Avatar
Hey - unfortunatley I didnt even get to them - I did the spark plug change instead.
I only did 9 out of 16 because I couldnt get to the T27's on the driver's side coil packs (torx driver was too long).
Tried to do o2 sensors but they just wouldnt break loose so I got some PB Blaster and decided to let it sit for a while.
I'll keep you in mind though as I wanna get this done ASAP.
alignment and tie rod problem? camber bolts? sightless R170 SLK Class 2 02-19-2008 01:07 AM
Anybody Done MB Front Camber Bolts? Hary Gahtoe W208 CLK Class 4 05-10-2007 11:45 AM
H&r Eccentric Bolts To Adjust Camber Hary Gahtoe W208 CLK Class 7 03-06-2007 01:04 PM
Camber bolts for rear and front.... Pej D. R170 SLK Class 20 10-14-2001 06:18 AM
dont lower your slk without having camber bolts installed ashroxamg R170 SLK Class 6 09-14-2001 06:01 AM
