Old 08-06-2008, 08:46 AM   #1 (permalink)
mpr2007's Avatar
Date registered: Jul 2007
Vehicle: 2001 E320 4MATIC, 210.082, 112.941, WDBJF82J61X051xxx
CPS Replacement
Reading through the posts, I've seen mention a calibration that needs to take place once the crank position sensor has been replaced. Is this needed and how is it done?
Thanks,
M
mpr2007 is offline   Reply With Quote
Old 08-06-2008, 09:07 AM   #2 (permalink)
Date registered: Mar 2007
Vehicle: 2001 E55
honestly, i just replaced mine and started the car. no codes or anything. not sure if i "got lucky" or something but I definitely did not calibrate anything.
FrankiE55 is offline   Reply With Quote
Old 08-06-2008, 09:41 AM   #3 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
The first I've heard of indexing the stock CPS on newer MB engines was ohlord's blithe reference to it in another thread...and his silence on the topic thereafter.
Meister Eckhart
Old 08-06-2008, 10:50 AM   #4 (permalink)
mpr2007's Avatar
Yea - before I dive in, just wanted to check. It sounds like many folks have done the replacement and there have been no comments on additional steps. The labor time in Alldatadiy shows labor at .8 hours - not enough time I would think to do much more than replace the sensor.
Old 08-06-2008, 11:05 AM   #5 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
He can't type with hat in his mouth.
I didn't do calibration on 2 CPS I replaced on 2 different cars. They run just fine.
The .8 hours doesb't cover fishing for dropped screw and drinking beer.
Kajtek1 is offline   Reply With Quote
Old 08-06-2008, 11:19 AM   #6 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
The relevant WIS procedure is AR15.12-P-2133A, Remove/install crankshaft position sensor.
It contains
If the crankshaft position sensor was replaced, a re-initialization must be carried out with STAR DIAGNOSIS in the menu item control module adaptations.
Replaced mine myself and didn't have this done and don't think I have any problems. It sure fixed the problems I was having.
Kent Christensen
Albuquerque
Old 08-06-2008, 12:20 PM   #7 (permalink)
ohlord's Avatar
Oh
yea of little faith
No SDS indexing is needed,the proper procedure is directly after replacement.
Start the engine and slowly bring the rpms up over a period of 2 minutes from idle to 2500 rpms,this allows the new cps to index itself to the ECU and really set it into sync with the flywheel indexers.Do it and the car will run better,don't do it and you may never know what you are missing
I haven't eaten any hats yet,nor do I run around with 10 year old brake fluid.However,It would be wise when the member that makes a habit of non maintenance of his and his family's vehicles learn something about anything before he opens his hat filled mouth and other orifices
ohlord
CPS replacement 230 V6 similar Bazzle R170 SLK Class 2 06-25-2008 11:10 PM
CPS failure symtoms but it's not the CPS problem joeml W163 M-Class 3 06-05-2008 11:05 AM
CPS ADCastro W210 E-Class 4 05-12-2008 01:21 PM
How to replace a CPS? JayP784 W208 CLK Class 18 04-16-2008 06:41 PM
Need a CPS? ganndallff R170 SLK Class 2 12-10-2007 02:38 AM
