Old 08-05-2008, 06:43 PM   #1 (permalink)
Musikmann's Avatar
Dashboard cluster issue ad nauseum
Hello Friends,
As soon as I started the car two times now my outside temperature reading was missing pixels (not in succession). After driving for about 5 minutes they came back to normal. I know this is probably a warning that the rest will begin to crap out eventually, but since I don't recall reading about this exact symptom I'd start a new thread. Does anyone have any input?
Regards,
MM
Old 08-05-2008, 07:17 PM   #2 (permalink)
Date registered: Nov 2006
Vehicle: 2002 e320
i have had a similar problem with the pixels coming and going, involving the gear selector /time display. i was able to improve (but not cure) it, using the procedure in the diy sticky, i.e.wedging a piece of foam to hold the contacts in place. paul
pvel is offline   Reply With Quote
Old 08-05-2008, 07:22 PM   #3 (permalink)
Musikmann's Avatar
Thanks to you Paul, I might try that.
Old 08-05-2008, 07:22 PM   #4 (permalink)
Date registered: Sep 2006
Vehicle: 2002 E320 sports limitted edition
Hey MM that is what happened to me. The rest of the Pixels on the temp reading will eventually go. Mine appear at different and for a while I was able to read the outside temp. I can no longer read it because not enough come back. I can live with it as I would perfer to spend $1000 on something else. I do not have the time to send it out for repair and after reading some horror stories about people who did send it out to save money and had issues when it came back, well no thank you. IF other pixs go if I still have my car I will take it to the dealer and let them replace it for $1000. It is a flat fee no labor since they said it is done in about 5 minutes once they get it in. I would rather it be temp pixs then any of the other ones
debbibaron is offline   Reply With Quote
Old 08-05-2008, 07:44 PM   #5 (permalink)
ohlord's Avatar
That's
what all the mb techs say about 5 minutes once they get it in
Old 08-06-2008, 07:23 PM   #6 (permalink)
Musikmann's Avatar
Debbi, that is a $1000 job? Ouch! It sounds as thought the part itself is the $1000 if they don't charge any labor since it's only a 5 minute job.
Old 08-06-2008, 07:39 PM   #7 (permalink)
peter_02AMG's Avatar
Date registered: Jun 2007
Vehicle: 2002 E55 AMG
I had the same problem, sent my off to BBA-reman. they fix it like new and life time warranty. Dealer can't fix it, that what they told me. they will tell you it need to be replace. a new cluster with dealer program & labor cost about $1500.
http://www.bba-reman.com/catalogue/D...ledProduct=556
E55 K L E E M A N N <
peter_02AMG is offline   Reply With Quote
Old 08-06-2008, 07:44 PM   #8 (permalink)
Musikmann's Avatar
Thank you too Peter. A tech at my dealer told me the same thing, that the only solution is to replace the cluster.
Old 08-06-2008, 07:45 PM   #9 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
You should add this link to the "Deals" sticky thread, above.
Old 08-06-2008, 08:16 PM   #10 (permalink)
ohlord's Avatar
bba
is in the diy's,already isn't it?
1983 240D Replacing Dashboard Cluster Lights valvano W123 E,CE,D,CD,TD,TE Class 3 06-20-2008 10:00 AM
1992 300se dashboard issue david patterson W140 S-Class 5 01-29-2007 11:19 AM
shaking steering wheeel on 92 300Se and dashboard issue oaklandw140 W140 S-Class 22 05-17-2006 09:31 AM
2000 S500 Dashboard / Cluster slswearingen General Mercedes-Benz 5 05-15-2006 06:55 PM
OBD Codes ad nauseum G1pilot W210 E-Class 2 10-02-2005 09:39 AM
