Drivers side window seems to stick every once and awhile, and will stop about mid way, when using the auto up feature; then I have to inch it up to close.
Q: What would be best to lubricant to use? white lithium grease, or WD-40? Any suggestions?
I think I'd first pop off the door panel to see what's going on, you might have something in or near the track that is causing it to bind, keep your fingers clear and then actuate the window up and down a couple of times with the panel off. If everything otherwise looks good I'd wipe out the old grease and then probably use a thin coat of Mobil1 synthetic grease, it's light enough it should be fine for that. White lithium should be fine but probably wouldn't last as long, and WD-40 would wash out all the old grease and be too thin to do much for very long.
Take care and enjoy the ride,
Greg
Could it be electrical emanating from the center console that probably needs a crc cleaner.
I hope Ohlord or Gregs210, MM is reading on this. Since my right rear window is doing this and also my drivers side making this halfway close intermittently.
Thanks.
I believe I think, so therefore, I think I believe !
