Old 08-03-2008, 03:44 PM   #1 (permalink)
covinsky's Avatar
Date registered: Dec 2006
Vehicle: 1999 500sl sport - 2001 e430 4matic - 2000 bmw 528i sport - 1966 corvette
exhaust leak
On my way home today, I ran over what looked to be an air filter of some kind, maybe off a large truck? When I got home and inspected the undercarriage, I noticed an exhaust leak coming from a short piece in the exhaust that looks like an accordion, between the passenger side catalytic near the engine and the other catalytic further back toward the middle of the car. I can see where this flexible exhaust section had been hit by something and damaged the bottom most part, and when the car is running I can feel a small amount of air (exhaust) coming from the damaged area. I don't have any check engine lights on, and the car is running normal. Does any one have any clue as to what I might expect? Will this cause any major problems?
Will I be able to have this repaired as I can image what that entire exhaust section must cost from Benz. I would be greatful for any opinions or advice.
Thanks Chris
covinsky is offline   Reply With Quote
Old 08-03-2008, 05:02 PM   #2 (permalink)
ohlord's Avatar
since
it is after the post cat sensor it will be no problem other than the noise. you should be able to get it patched at any good muffler shop.Most carry the flex pipe.
locating a exhaust leak skirrby W210 E-Class 2 05-07-2008 07:09 AM
Help! Exhaust leak on my 32? SLK32AMG R170 SLK Class 5 11-11-2006 12:50 AM
Found the exhaust leak danwatt W126 S,SE,SEC,SEL,SD,SDL Class 0 08-23-2005 12:31 AM
Drat! Exhaust Leak!! ccweems W163 M-Class 9 09-22-2004 06:59 AM
anyone experience an exhaust leak??? tsanjose W163 M-Class 6 12-17-2002 02:12 PM
