Old 08-03-2008, 02:15 PM   #1 (permalink)
blm
blm's Avatar
Date registered: Apr 2008
Vehicle: 1999 E320
Send a message via AIM to blm
Rack Boot Replacement
I was backing out a friends concrete driveway when I drove over a broken piece that popped up and tore my boot. Obviously now p/s fulid is leaking and I need to replace it. Is there anything special I need to consider when doing so?
blm is offline   Reply With Quote
Old 08-03-2008, 02:47 PM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Obviously, you want to ensure that the tie rod end is at the same place. I would mark the tie rod and end so that I know how far to thread the end, and get it at the right angle (partial turn on the threads).
Also, there is a special tool to set the clamps.
Old 08-03-2008, 03:46 PM   #3 (permalink)
blm
blm's Avatar
Vehicle: 1999 E320
What is this tool you speak of?
Old 08-03-2008, 06:13 PM   #4 (permalink)
I can't remember the name of the tool. It is probably the same tool that is used for CV boot clamps.
Old 08-04-2008, 09:18 AM   #5 (permalink)
blm
blm's Avatar
Vehicle: 1999 E320
Now that I think about it...should there be any fluid leaking out? Would that mean that my r&p seal is damaged thus requiring me to replace the unit?
Old 08-04-2008, 09:45 AM   #6 (permalink)
E-Class Owner's Avatar
Vehicle: 1997 Mercedes Benz E420
If...
the Mercedes design is similar to most other racks, the boot is there to protect the rack's shaft and seals from being damaged by dirt/grit, etc., and is not intended to hold fluid.
You may have a larger problem there...
Good luck,
JR
E-Class Owner is offline   Reply With Quote
Old 08-04-2008, 10:13 AM   #7 (permalink)
blm
blm's Avatar
Vehicle: 1999 E320
That is what I thought (after the fact). I looked on AutoHaus for a r&p but couldn't find one. What is another recommended parts supplier? Thanks all for the help.
Old 08-04-2008, 02:36 PM   #8 (permalink)
blm
blm's Avatar
Vehicle: 1999 E320
Now that I have deducted that the steering rack seal is damaged, is it possible to replace the seal?
Old 08-04-2008, 03:40 PM   #9 (permalink)
How much fluid is leaking? Certainly, some fluid retained in the boot should not be a sign for alarm. It was working properly before the boot tore, right?
Old 08-04-2008, 03:47 PM   #10 (permalink)
E430SportMB's Avatar
Date registered: Dec 2007
Vehicle: 2000 MB
Can you post some pictures of damage for everyone to see. Thanks !
I believe I think, so therefore, I think I believe !
E430SportMB is offline   Reply With Quote
'99 ML430 Power steering fluid leak from steering rack boot? XxAndrijanXx187 W163 M-Class 10 05-06-2008 01:52 PM
CV boot replacement Cyberbach W123 E,CE,D,CD,TD,TE Class 12 11-16-2007 07:38 PM
Inner + Outer CV boot Replacement ??? 300sd W126 S,SE,SEC,SEL,SD,SDL Class 8 09-26-2007 07:17 AM
Axle boot replacement tool Trevor Sarty W123 E,CE,D,CD,TD,TE Class 0 04-11-2007 05:56 AM
Shift Boot Replacement EternalE W124 E,CE,D,TD Class 3 02-02-2006 02:58 PM
