Old 08-02-2008, 05:10 PM   #1 (permalink)
Date registered: Aug 2006
Vehicle: 1997 E320 Avantgarde
Brake bulb
Not having much luck with the electrics lately. My brake bulb has blown. I was given a 5 W instead of a 4. I placed it in the bracket - seemed a little loose. I inserted it into the unit and the globe fell out. Now it's trapped in the brake lens cavity. Is unsrewing the rear assembly from the booth the best approach? Remember I'm tool challenged!!
laksa is offline   Reply With Quote
Old 08-02-2008, 05:41 PM   #2 (permalink)
ohlord's Avatar
long nose
needle nose plier to twist it out.
Old 08-02-2008, 06:06 PM   #3 (permalink)
Date registered: Aug 2007
Vehicle: 1998 E320 4matic wagon
vacuum cleaner with small attachment? that might work
korbenz is offline   Reply With Quote
Old 08-02-2008, 07:02 PM   #4 (permalink)
Thanks for the advice gentlemen. I tried but no success. Finally used a blob of 'blutac' sticky plasticene stuff (not sure what you call it in the US- prob 'Blutac' too!!) and attached it to a pointy nose plier and gently pulled it out. Replaced the globe and it works a treat. Thank you anyway.
Brake light bulb Hi Fi W210 E-Class 16 06-28-2008 07:01 PM
Warning light for brake bulb always on echandler W140 S-Class 6 04-14-2008 07:08 AM
Brake Light Bulb milcrat W163 M-Class 6 09-13-2006 05:39 PM
Replace Bulb of Brake Ligth? SauLV W202 C-Class 2 09-02-2004 09:58 AM
Brake light out, bulb is still good. Nektopoli R170 SLK Class 4 06-06-2003 01:40 AM
