Old 08-01-2008, 11:39 PM   #1 (permalink)
Date registered: Jul 2008
Vehicle: 1998 E 320, 86K miles
Programming the Climate Control
Hello Everyone,
First off, I'm new and this site is Awesome. I've been searching for hours and a lot of the information has done wonders for me with some little issues. I have a 1998 E 320 sedan with 86K miles. This is actually two questions:
1. I had a few codes on my climate control and thanks to you guys I was able to figure out which sensors were bad, but I have one code left that I can't find anything on and it's B1 432 which I believe it translates to "Maximum Heat", but I have no Idea what Maxium Heat means.
2. I also was looking at the Programming and I couldn't find anything on this
site that shows what the P1 and P2 settings should be, I wanted to check to make sure I have the right settings that were in there. Mine shows P1 is 70 and P2 is 150, but have no Idea what that means.
Any helps would be appreciated.
Thank You,
Dean
dkrassop is offline   Reply With Quote
Old 08-01-2008, 11:46 PM   #2 (permalink)
E=MBČ
GermanStar's Avatar
Vehicle: GermanStar.net
Welcome to BenzWorld Dean! I'm going to slide your query over to the w210 section, where I'm sure you'll garner a helpful response or three.
German Star
GermanStar is offline   Reply With Quote
Old 08-02-2008, 04:03 AM   #3 (permalink)
ohlord's Avatar
That is
a non USA diagnostic code,ignore it.Or clear it.What was your problem with the a/c?Is it not working or are you the type that likes to figure out how to make it not work by messing with the programming?
values 1-8 and errors
How to Diagnose Air Conditioning Malfunctions | EclassBenz.com
why are you checking programing?
ohlord
Old 08-03-2008, 02:46 PM   #4 (permalink)
Hey ohlord,
Thanks for getting back to me. I'm definitely NOT the kind of guy that messes with things. I had a radio installed by Firedog and since I got it back it seems like the Air was not blowing at Max Speed, but about half speed even on Max. I already did steps 1 - 8 that you mentioned and it turns out to be the Blower Regulator and I read that I can use one from a W140 instead of replacing the Blower and Regulator.
Anyhow...I wasn't sure if FireDog disconnected power because the buttons that control where Air is directed (defrost, feet, face) on the climate control didn't seem to be functioning properly....meaning if I put it on Defrost (Front Window), Air would go to the Front Window and to the Middle (Face) as well so that's when I started checking the programming because I wasn't sure if they disconnected power and I had to reset and program everything. Did the P1 and P2 values seem correct to you?
Thanks again for your help.
Dean
Old 08-03-2008, 05:06 PM   #5 (permalink)
ohlord's Avatar
Check
the cabin and pollen filters if they have not been changed.You can test voltage to the fan in the diagnostics,and the flaps are controlled by the pse are you sure they did not unplug it and mess up the tubes?
Old 08-04-2008, 02:25 PM   #6 (permalink)
Hey Ohlord. The the filters were replaced last week, I believe there was four of them. On the diagnostics, below are the numbers I get on the left and right after sensors 1 - 8. Not sure what they mean:
9 = 10
10 = 6.0
11 = 1.8
12 = 4.2
20 = 4.6
21 = 126
22 = 00
23 = 00
29 = 13.3
40 = 71
41 = 36
42 = 80
43 = 160.
Also, How do I check if they unplugged the pse? what the heck is a pse? Sorry about all the questions, I'm learning as I go.
Thanks again.
Dean
Old 08-06-2008, 01:05 PM   #7 (permalink)
Date registered: Feb 2006
Vehicle: 2001-W210-CAPRI METALIC BLUE-
P1 and P2 ??
How did you get these values and what do they do?
THX
B
The finest example of automobile engineering in the world
Floats like a CADI
Stings like a BMR
Stingy as a Prius
and.... all Mercedes Benz.
MRBSMITH is offline   Reply With Quote
Old 08-06-2008, 07:53 PM   #8 (permalink)
Hey Smith,
I got the P1 and P2 values by turning the Left to High and the Right to Lo, turn the ignition off. Press "REST and Turn ignition "ON" simutaniously. P1 will flash on the Left side and will have a value on the Right side. To go to P2, press EC. You can change the values of P1 or P2 by using the right temperature selector (blue = <; red = >).
I have no idea what it's used for or what the precautions are if they are changed, that is my question as well. Mine are set at 70 for P1 and 150 for P2.
Hope it helps.
-Dean
Old 08-06-2008, 08:14 PM   #9 (permalink)
ohlord's Avatar
Leave them
alone you need a base 16 code to add values to trigger the compressor when it won't trip on due to various factors.Best left to someone who has done it or a shop.(I think it is base 16)
ohlord
Old 08-06-2008, 08:19 PM   #10 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
It's really binary, something that the IT industry calls a "bit field." But for hex (or hexadecimal, base 16), it is a very easy conversion between hex and binary so this is often used.
As an aside that you won't care about, in floating-point numbers, the "dot" is generically called a "radix." That radix is called a "decimal point" in base 10, but it's a "hexadecimal point" for base-16 numbers, and a "binary point" for base 2.
climate Control Hallsound W124 E,CE,D,TD Class 0 04-09-2008 10:23 PM
Heat Stuck on, Climate Control Panel/Climate Control Servo Problem? 123Doug W123 E,CE,D,CD,TD,TE Class 15 09-18-2007 01:15 AM
Climate Control bullyben W201 190E, D-Class 2 12-15-2006 07:58 PM
cruise control vs. climate control CCarlisle W123 E,CE,D,CD,TD,TE Class 0 11-04-2005 10:51 PM
EC on climate control always ON mgyl W210 E-Class 12 06-04-2004 09:20 AM
