Old 07-25-2008, 08:17 AM   #1 (permalink)
Date registered: Aug 2007
Vehicle: 2000 E320
ABS ESP
2000 E320, 94 k miles: While driving yesterday, the ABS & ESP light came on and the FSS monitor displays "ABS Visit workshop and ESP Visit workshop". After stopping for a fill up and starting the car, the lights & the message are gone. The light or the message did not show this morning on the way to work. After going thru the forum, my first suspicion is the brake switch. Any input, as always, is greatly appreciated. What are the implications of using the car without fixing it?
fdte320 is offline   Reply With Quote
Old 07-25-2008, 09:23 AM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
The brake lamps are likely working properly, but you should check.
You might as well just replace the switch, since it's cheap and easy. Be sure to get the OEM part; substitute switches don't seem to hold up.
And welcome to the forum. Please take a moment to complete your user profile, available via the "User CP" link.
Old 07-25-2008, 09:44 AM   #3 (permalink)
Vehicle: 2000 E320
Thanks for the reply. Yes the brake lamps are working. I was just quoted around $17.00 by a dealer for the brake switch and I am going to replace it. I already took out the cover under the steering wheel. Unfortunately, I broke one of the clips (the one on the right). Hope the glue works. So anyone working on this, be careful removing the cover. I learned it the hard way.
Old 07-25-2008, 11:38 AM   #4 (permalink)
mpr2007's Avatar
Date registered: Jul 2007
Vehicle: 2001 E320 4MATIC, 210.082, 112.941, WDBJF82J61X051xxx
Was it raining when you got the warnings? I had this happen twice when it was wet, and while turning a corner at a stop sign. Didn't do it again, and a week later the wear indicator came on - found I did indeed need new front pads.
Wondering if water plays games with an exposed or nearly exposed wear sensor?
mpr2007 is offline   Reply With Quote
ABS ESP Question Carl Aydelotte R170 SLK Class 6 04-16-2008 12:54 PM
ESP/BAS/ABS KADE W210 E-Class 15 12-06-2007 09:48 AM
ESP and ABS light on...HELP!! TyBenzo W210 E-Class 8 12-08-2006 06:51 AM
abs/esp problem nis General Mercedes-Benz 1 01-14-2006 12:31 PM
ESP ABS binelus W210 E-Class 2 07-25-2005 06:04 AM
