» Site Navigation
» Other Sites
Old 07-25-2008, 06:53 AM   #1 (permalink)
Date registered: Nov 2004
Send a message via AIM to shonne Send a message via MSN to shonne Send a message via Yahoo to shonne
AUX Fan Issues
I recently replaced the water pump. Now, my 1998 e320 runs warm (85-90 C). I noticed the aux fan was not running and the AC blew hot. I replaced a blown 15A fuse and recharged the AC. The AC is now cold and aux fan will come one when the AC is on when it did not before.
I am not sure if I need to replaced the coolant sensor switch and/or thermostat. I read where a coolant sensor switch failure was produce code b1231. How do I pull codes?
Thanks in advance.
shonne is offline   Reply With Quote
Old 07-25-2008, 08:54 AM   #2 (permalink)
I pulled the codes and got:
B1459 Series interface (K2) connection to instrument cluster (A1)
B1227 Outside temperature indicator temp sensor (014)
B1232 Refrigerant pressure sensor (B12)
B1234 Sun sensor (B32)
B1235 Emissions sensor (B31)
Aux fan run when Engine fan runs? Is it possible? Haroundb W123 E,CE,D,CD,TD,TE Class 48 07-22-2007 08:17 AM
aux fan/cooling fan m4411b W201 190E, D-Class 12 03-06-2006 08:00 AM
Aux fan benzmeover W123 E,CE,D,CD,TD,TE Class 0 07-01-2005 07:03 AM
Aux Fan help mikec92117 W123 E,CE,D,CD,TD,TE Class 2 06-26-2005 08:20 PM
Aux. Fan... Benzboy03 W201 190E, D-Class 1 11-13-2003 02:08 AM
