I have a 1997 e300 Diesel. Emergency flashers work fine (so I assume all bulbs are good), so does the left turn signal (normal relay sound). High and low head light positions also work fine. However, the hi beam flasher does not, nor does the right turn signal (relay sound is different). The combination switch is OK, and so is the light control module. Im stuck ! any other ideas on where to look next ???
I have sorta the same problem. My high beam works when my lights are on, but when I flash it, not working, regardless of whether the light is on or off.
