Old 07-29-2008, 08:44 AM   #11 (permalink)
mpr2007's Avatar
Date registered: Jul 2007
Vehicle: 2001 E320 4MATIC, 210.082, 112.941, WDBJF82J61X051xxx
So I finally got a reader and pulled the codes and nothing... no codes or pending codes. I did notice while watching the rpm's at idle it seemed to fluctuate between 810 and 920 rpm's. Seems like a pretty wide swing. Any more thoughts on the 'almost' stalling issue?
mpr2007 is offline   Reply With Quote
Old 07-29-2008, 08:56 AM   #12 (permalink)
Date registered: Mar 2007
Vehicle: 2001 E55
I would check, Crank position sensor, O2's, cats and secondary air injection pump. I know that's a lot of broad "stuff" but you have a very vague problem. Could be anything, the purge pump/air injection only runs on a cold start so possible one of them is malfunctioning and throwing off your cold start fuel mixture. similarly the CPS or 02's could be on the fritz and causing similar A/F or timing issues. Cats are random, but if they are clogged it could cause all sorts of stuff.
FrankiE55 is offline   Reply With Quote
Old 07-29-2008, 11:16 AM   #13 (permalink)
ohlord's Avatar
Changed
your fuel filter lately?Not only will it affect fuel pressure ,thus idle ,but can cause intermittent maf codes.
Clean your maf for good measure crc brand maf cleaner,diy in the diy section.Don't wipe it with paper.
Old 07-29-2008, 12:27 PM   #14 (permalink)
mpr2007's Avatar
I have not done the fuel filter yet - I will add that to my list. And I happen to have a can of MAF cleaner and will try that also. Thanks.
Old 07-29-2008, 12:36 PM   #15 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Originally Posted by Hi Fi View Post
I am close to 100K KM presently on my car. I am the second owner of this car.The previous owner did much of his milage in the city,and I am wondering if the o2 sensors being driven in the city need to be changed earlier than with highway milage?Did you buy your o2 sensors at the dealer? Where is the best place to get them? Thank-You.
Hey, Hi Fi, generally speaking it is best to start a new thread rather than hijack another. In this case O2 sensors are 100K items as noted, if you're close and plan on keeping the car then just replace them. Highway or City, no matter really, they just wear out and MB says 100K to change them. Might last less time, might last more, just like a light bulb, but that is the spec.
Great source is Auto Parts at AutohausAZ - OEM Auto Parts - Discount Replacement Parts, Resources and Car Care Tips as has been noted many times throughout this site. They have the pre-wired exact replacement (roughly US$400 for the set) or you can buy the Bosch "universal" ones and wire them in yourself to the existing connector if you feel competent to do that, all four are around US$135 or so. Just don't buy them from Ebay or you'll get to buy them twice, plus the task of changing them twice. I know you're up north, call autohaus and they probably ship up there too.
Take care and enjoy the ride,
Greg
Meister Eckhart
Friends car stalled, need help Solidjake W163 M-Class 3 05-14-2008 10:09 PM
06 C280 4 Matic Stalled? DJYoshi W203 C-Class 0 09-06-2006 08:55 AM
Stalled out this morning! Niloc W123 E,CE,D,CD,TD,TE Class 3 02-25-2006 09:22 AM
vehicle stalled mmm etr W208 CLK Class 1 04-22-2005 12:46 PM
engine stalled and won't start right away pete168 W201 190E, D-Class 2 11-21-2002 07:53 PM
