Old 07-23-2008, 01:35 PM   #1 (permalink)
Date registered: Jul 2008
Vehicle: 1996 e300d
1996 e300d engine oil level low warning
I keep getting a indication of low engine oil level via the multifunction indicator but when I check the dip stick its fine.
I am new to the MB world so please forgive me if this is a dumb question but could it be telling me its time to change the oil? The car had been in storage for a while before I picked it up as a project.
ctsailor is offline   Reply With Quote
Old 07-23-2008, 01:39 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
If you are 100% certain the level is fine then I would check the level sensor and the wiring leading to it.
If the car had been in storage a while my recommendation would have to to change it as one of the first rites of passage to your ownership. At this point, the sooner, the better although that should have no effect on the malfunction display.
Welcome to the forum, too.
Take care and enjoy the ride,
Greg
Old 07-23-2008, 01:55 PM   #3 (permalink)
Vehicle: 1996 e300d
The level is almost to the max mark. A oil change is planned ASAP. I have been busy getting the car to run and repairing some minor collision damage first. I can do a reset to get the msg to go away but it is back on the next start up.
Could you tell me where the oil level sensor is located? I have found most of the service manuals lacking in details!
Old 07-23-2008, 02:04 PM   #4 (permalink)
gregs210's Avatar
On the I6 diesel I have no idea. You can go to STAR TekInfo - EPC Online and sign up for free for the parts catalog and that may yield some useful results, although for sensors under the hood it is usually pretty hard to locate things. There are lots of members with these cars so my guess is stay tuned and one of them will be jumping in soon with more info for you.
The FSM is pretty inexpensive, so if you plan on doing your own work -- which it sounds like you are -- that would be a wise investment.
Greg
Old 07-23-2008, 02:30 PM   #5 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
The sensor is on the left side of the engine, bolted into the oil pan.
Check Engine Oil Level at next refueling - Warning ojack GL Class 8 10-24-2007 05:32 PM
Can anyone help on 2001 C240, problem with smart key and "Reduce Engine Oil Level" warning light? burryo W203 C-Class 10 09-18-2007 09:45 PM
ML Class "Check engine oil level warning" 2006 The Workshop MB W164 M-Class 4 10-18-2006 06:43 AM
Engine Oil level low Benz Devil W126 S,SE,SEC,SEL,SD,SDL Class 21 10-16-2006 09:38 AM
Low Engine Oil Level Switch? Sergio W124 E,CE,D,TD Class 0 06-13-2005 08:57 AM
