Old 07-22-2008, 12:12 PM   #1 (permalink)
Booker's Avatar
Date registered: Jul 2007
Vehicle: 2000 E430 Sport
Left turn indicators are on crack.
My left turn signal is really tweaking out. Just the left though, not the right. For some reason when I turn on the left signals, it blinks at about 3x normal speed. Very odd. What's causing that?
Why, oh why, did it take me so long to buy a Mercedes??
Booker is offline   Reply With Quote
Old 07-22-2008, 12:19 PM   #2 (permalink)
Date registered: Aug 2007
Vehicle: W210 1998 E430
Crack is right. As in crack in bulb. As in not working bulb. As in replace the burnt out bulb.
It does this to alert you that something is wrong with (most likely) the turn signal bulb. Do you have a lamp defective warning on your instrument cluster as well?
Benzboy210 is offline   Reply With Quote
Old 07-22-2008, 12:54 PM   #3 (permalink)
me beautiful's Avatar
Date registered: Jun 2008
Vehicle: E300TD 1997 W210 Running on chippie oil at 99.8%
Both for me
my left and right do the same. Really fast. Still working though
Good post as I'll check all the light bulb and if this is not this someone might have the answer.
me beautiful is offline   Reply With Quote
Old 07-22-2008, 01:05 PM   #4 (permalink)
Booker's Avatar
No, sir. If this is really the case, what an odd redundancy. Why would the engineer in both the crack-head indicators, AND the lamp defective idiot warning? Strange
Old 07-22-2008, 01:12 PM   #5 (permalink)
I don't know enough about the blinker system to go any deeper, but I think it operates on resistance and if resistance changes, you get the faster blinking. So the bulb could be on its last legs, but not completely dead. Or a bad connection between the bulb and socket, etc. Either way, I would check the bulb and replace it if you have a spare, see if this fixes it.
Old 07-23-2008, 07:40 AM   #6 (permalink)
Date registered: Mar 2008
Vehicle: CLS550 Master Lease, 1990 300zxTT, 2000 camry
The reason the blinkers go faster is because when one light goes out you reduce the resistance of the circuit. This increases the amperage flow through the circuit and causes the circuit breaker to set and reset faster. Its not engineered to do that its just physics . The idiot light on the dash is engineered to be there though.
kyle21nluvnit is offline   Reply With Quote
turn signal indicators/instrument cluster not working. HELP ! cyne wan W126 S,SE,SEC,SEL,SD,SDL Class 0 11-16-2006 07:42 AM
No left hand indicators!! HELP!! vanman V-Class 2 09-19-2006 10:54 AM
Turn signal indicators Dukming R129 SL Class 11 10-03-2005 04:41 AM
Amber turn indicators and Tailights on ebay matty j G-Class 0 05-09-2004 10:35 PM
FS: brand new OEM Bosch clear Euro front turn indicators for W202 C class Guest (MBNZ) W202 C36 AMG, C43 AMG 0 04-18-2002 07:11 PM
