Old 07-22-2008, 12:01 PM   #1 (permalink)
Date registered: Jun 2008
Vehicle: 1997 E420
Remote Receivers - Can they be repaired?
My 97 E420's remote receiver in the door works, but the window is cracked. The receiver on the trunk does nothing and the window is cracked. Can the windows be sourced, or do you need to buy the receivers as a unit?
thx
todd
97 E420
CrossT is offline   Reply With Quote
Old 07-22-2008, 12:15 PM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Look it up in the EPC. It's free for USA cars.
epc.startekinfo.com. You must enter a credit card number, but there is no charge against it.
Old 07-22-2008, 07:47 PM   #3 (permalink)
Vehicle: 1997 E420
Went there. Good resource. Bad answer. I can't believe there is only the option of replacing the vin coded dealer only receiver for $450 for just the part only because the plastic cover on the door handle covering the receiver is cracked.
So, my question is; Is the clear plastic cover integral to the receiver or part of the door handle?
thanks
todd
97 E420
SLK32 after being repaired euvertio R170 SLK Class 15 06-01-2007 08:09 AM
Portable GPS Receivers for Infrared Laminated Glass cardiology W164 M-Class 7 06-06-2006 09:27 AM
hitch receivers bill6ft6 W126 S,SE,SEC,SEL,SD,SDL Class 3 10-03-2005 05:34 AM
Repaired my convertable G-Power G-Class 1 03-12-2005 04:47 AM
left door and trunk lid infrared receivers does not work stillee W140 S-Class 0 06-29-2004 01:43 PM
