anyone have a good way to break loose a stripped oil pan bolt? It never occured to me to check the oil drain bolt when I bought the Benz, but apparently I should have. This thing is stripped to all hell. I've tried everything to get it off, but just is not happening.
anyone got some special trick to breaking it loose? I really need to change the oil before this weekend.
also, anyone have info on a replacement plug if/when I get it off? What size, where to get, etc. any info is appreciated.
1. you can use a set of vice grips.
2. you can use a dremel to cut a slot in it, or reshape the hex shape to get a socket on.
3. craftsmen makes a set of sockets for stripped bolts
4. If you're super desperate and nothing has worked, you can weld a socket to the nut.
5. Get a mityvac and suck the oil through the dipstick and don't worry about the drain plug.
vice grips didn't work the last 2 times i tried. Seemed like all I did was strip it more. I think cutting a slit to get a flathead in there might be my best bit.
at the store call first if in stock Harbor Freight Tools - Quality Tools at the Lowest Prices
topsider clone,or for 5 bucks you can slip a piece of longer tubing that is the diameter of the dipstick tube into the hand held siphon pump sold at hb tools and pump the warm oil into an old anti freeze container.Mobil1 0w40 euro spec only and fleece filter a must.
ohlord
oops went up to $25 http://www.harborfreight.com/cpi/cta...emnumber=45403
I'll have to look into the mityvac as well.
Are you using vice grips with a flat jaw or with the more rounded jaw? I've always had more success with the rounded jaw models because you can get more surface area contact against the stripped drain plug.
