Old 07-21-2008, 11:01 PM   #1 (permalink)
Date registered: Jul 2008
Unhappy 1998 e 320 Climate Control with no display?
Hi guys!
I am trying to help out with my sister's E320...The Climate control unit shows absolutely nothing/no display - obviously no control of the buttons. Is there a fuse for the unit?
kartopics is offline   Reply With Quote
Old 07-21-2008, 11:22 PM   #2 (permalink)
ohlord's Avatar
Fuse 4 or 7
controls instrument cluster and climate control display,located in the main fuse panel by the battery.If not that pull the unit with the special radio/climate control keys and check that the unit is plugged in.
ohlord
best to check fuses with a multimeter on ohms setting instead of just looking at them,sometimes they can fool you.
rest of fuse chart is located in diy section at top of forum under electrical.
Old 07-21-2008, 11:24 PM   #3 (permalink)
Date registered: Aug 2007
Vehicle: 1998 E320 4matic wagon
fuses are driver side under the hood
and I'm not sure if your talking sedan or wagon but on my wagon there are also fuses under the middle row seat, (passanger side) hopefully you already found them.
korbenz is offline   Reply With Quote
Old 07-22-2008, 08:47 AM   #4 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
And more on the end of the dash, under a panel that is behind the driver's door. And yet more on top of the K40 relay module.
Is that all of them?
Old 07-22-2008, 12:29 PM   #5 (permalink)
ohlord's Avatar
4 and 7
are for the instruments and they are by the battery.
Climate control display mercman57 W210 E-Class 5 03-31-2007 04:42 PM
Climate Control Display... how hard? LondonThing W210 E-Class 4 02-03-2007 05:02 PM
E 320 1998 Climate control problems; artist W210 E-Class 1 08-13-2006 04:50 AM
Climate Control display dfraz R129 SL Class 7 01-30-2005 07:33 AM
ML 320 1998, Clock display azmaway W163 M-Class 3 01-16-2003 02:43 PM
