Old 07-20-2008, 01:09 PM   #1 (permalink)
Date registered: Jul 2008
Little Help, AC not blowing any air
I have an 2002 E320, and last night randomly the AC stopped working. I can hear the vents opening but no air is coming out even when I set the controls to max. I checked all three fuse boxes but couldn't find any reference to blower or AC. Anyone know what if could be? Also, if anyone knows which fuse box I should be looking in, that would be a great help.
Thanks,
Azeem
zimzyma is offline   Reply With Quote
Old 07-20-2008, 01:16 PM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Hello Zimzyma and welcome to the forum. Please take a moment to complete your user profile, available via the "User CP" link.
I would access the blower assembly and check for voltage at the blower motor. It should be constant battery voltage. If you have no voltage, continue to hunt for the fuse. It may be on top of the K40 relay module, in the module box under the hood.
If you have voltage there, disconnect the negative lead to the blower (goes to the regulator) and ground it.
If the blower runs at full speed, the problem lies in the regulator (likely) or the pushbutton unit (less likely). If the blower doesn't run at all, the problem is the blower motor.
Old 07-20-2008, 01:41 PM   #3 (permalink)
Thanks! I found the fuse, and there was nothing wrong...tried the AC again and it is working fine. I do have a strange feeling that I have an electrical problem as this is the third seemingly huge issue that basically occurred only once and never again (ESP and ABS went out, Car didn't start, A/C stopped) in the last 6 months. Thanks again.
Old 07-20-2008, 01:55 PM   #4 (permalink)
Yacht Master's Avatar
Date registered: Nov 2006
Vehicle: E-ZGO 53 HP., 99 E 430 sport, 04 E55 AMG, 2008 Tahoe LTZ Sold Porsche to Brother
You need to start looking around for a bad connection, (assuming battery is OK).
I would start in the battery compartment, make sure all connections are secure then check under the hood, pay close attention to the ground terminals.
http://w210.pietrzyk.net/electrical.htm
Yacht Master is offline   Reply With Quote
AC fan not blowing any air. JeffreyP W210 E-Class 8 06-28-2008 09:58 AM
Rear A.C. blowing warm air (while front A.C. blows cold air): Help erikluca W163 M-Class 12 06-17-2008 04:34 PM
Air conditioning not blowing cold air Mercedesguy1 R170 SLK Class 17 05-21-2008 06:16 AM
air conditioner stopped blowing cold air 86 420 sel W126 S,SE,SEC,SEL,SD,SDL Class 10 07-20-2004 11:26 AM
Air conditioner not blowing cool air 400SEL W140 S-Class 2 07-13-2003 01:07 PM
