» Site Navigation
» Other Sites
Old 07-18-2008, 09:31 PM   #1 (permalink)
Date registered: Nov 2006
Vehicle: 02 e55 AMG blk/blk chr. 18" AMG's
HELP NEEDED REAL QUICK PPLLLEEEAASSE
OK SO I JUST DID THE PIXEL REPAIR FOR CLOCK AND TEMP. CLOCK WAS EASY TEMP TOOK 3 YOURS TO GET JUST RIGHT PUT BACK TOGETHER AND NEEDLES WERENT REGISTERING RIGHT, NOTICED THAT DIALS WERE RUBBING ON NEEDLES CAUSING THE CLICKING OTHERS HAVE EXPERIENCED, FIXED AND PUT BACK ALL NEEDLES MOVING SMOOTHLY BUT, MY TACH IS AT 100-200 AT IDLE I THOUGHT WHEN YOU PUT THE KEY IN ALL THE NEEDLES RESET THEM SELVES? PLEASE HELP W/ ANY INFO ITS BEEN A LONG DAY FOOLIN WITH THIS BEAST AND IM BOUT TO PULL OUT MY HAIR ( OR DASH!) THANX
E55STYLE is offline   Reply With Quote
Old 07-18-2008, 09:53 PM   #2 (permalink)
Date registered: Apr 2008
Vehicle: 1997 e320
What is your question.. Where the needles are at idle?
Whalermax is offline   Reply With Quote
Old 07-18-2008, 10:00 PM   #3 (permalink)
WELL I BELIEVE IT WAS ALWAYS ABOUT 8-900 MAINLY I WANT TO KNOW WHO TO SET IT BACK CORRECTLY IF I MOVE IT BY HAND IT RESETS IT SELF BUT UNLESS MY CAR IS IDLING AT 200 RPM ITS NOT RESETING ITSELF CORRECTLY
Old 07-19-2008, 02:35 PM   #4 (permalink)
still havin problems!
So i checked again this morning and after my car warms up and the idle stabilizes its still at like 200-250 any ideas? also if any one will direct me to where i can fill out my profile that would be greatly appreciated. i remembering being asked for one when i signed up but cant find it now.
02 e55 55,000 miles all original black on black thanx
Old 07-19-2008, 02:40 PM   #5 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Your profile is available via the "User CP" link.
I can't say what's wrong with your car, but your engine isn't idling at 200 RPM. It won't run that slowly. I would suspect a bad instrument cluster, since your engine is actually running.
Old 07-19-2008, 02:57 PM   #6 (permalink)
tanx matt for the link as far as the cluster it seems to work fine every thing does as its suppose to it just the rpms are about 650-700 lower than theyre suppose to be. but when i hit the gas the tach moves like it should. has anyone else open theyre cluster before? all the other needles seem to go back home after starting no matter where i put them.
Old 07-19-2008, 04:20 PM   #7 (permalink)
It is possible that your needle shifted on the shaft, although I have not heard of this problem before.
If it is consistently 700 RPM off, this may be the case. You could remove the needle (after carefully looking where it rests when off the peg) and place it back in the correct position. Doing this will require removing the instrument panel and dismantling it, so you'll want to know exactly how far to move the needle before you start.
Old 07-19-2008, 04:53 PM   #8 (permalink)
Im sure it was not moved on the shaft i was real gentle with it apart ive searched through thi diy what have other people done with the needles when putting cluster back after repair? like i said gas, temp, speedo all reset when re powered up and seem to be correct but the tach reset and is now off, can i reset guages some how? battery disconnect, some button combo? thanx again guys appreciate any in;put or experiences.
Old 07-19-2008, 05:24 PM   #9 (permalink)
fixed it i think
ok i think i figured out myself. all the needles if you move them by hand have something that they hit that stops them in the right spot when reseting. some how when fixing pixel my stopper got pushed to far under zero so i swung the needle past redline and hit the stopper that way and pushed it farther clockwise around there by pushing the zero stopper back towards zero where it should have been. kind of confusing i know but seems to have been the problem thanx for at least answerinbg me matt.
CARFAX anyone.......Quick Help Needed jh225 General Mercedes-Benz 4 04-15-2008 11:13 AM
Quick Help Needed Please rad006 W203 C-Class 5 02-19-2008 04:21 PM
I Saw The REAL Quick Park System Today BKHammond W204 C-Class 0 10-05-2007 06:57 PM
Quick help needed please, THANKS! Designo_E320 W210 E-Class 5 06-18-2007 11:08 AM
Real Quick Question? salamanca W124 E,CE,D,TD Class 1 06-01-2005 02:29 PM
