Old 07-18-2008, 08:28 PM   #1 (permalink)
Date registered: Jun 2008
Vehicle: 2001 E 430 4maic
Lowering a 4matic...Is it really expensive?
In a previous discussion it was mentioned that lowering a 4matic would be very expensive.
Can anyone tell me about how much vs. a Non 4matic?
Is it my impression or are the 4matics slightly elevated vs. non 4matics. I just recently noticed the rather large gap in the wheel well...or is it just me?
Thanks
Rafael Leon is offline   Reply With Quote
Old 07-19-2008, 06:30 AM   #2 (permalink)
illest's Avatar
Date registered: Sep 2006
Vehicle: 98 320
Changing the spring pads is the cheapest way to lower the car a little. Beyond that getting lowering springs for the 4 matic can be expensive.
4matic lowering - MBWorld.org Forums
www.razoredgestudios.com
illest is offline   Reply With Quote
Old 07-19-2008, 06:39 PM   #3 (permalink)
ohlord's Avatar
Vehicle: 99 e320 wagon,bmw,vw,mgb,mg midget,subaru wagon
You
can remove the springs and take them to a good metal fabricator and have exactly 1/2 coil cut off with a cold saw.Not a torch,cold saw only.Get it aligned afterwards.Old school drop but it works on the benz,then you can fine tune with pads.
ohlord
ohlord is online now   Reply With Quote
Old 07-20-2008, 04:23 PM   #4 (permalink)
Date registered: Sep 2002
Vehicle: w210 e-class
I would not chop the springs on your car, that is really unsafe. If you want a huge drop, you will have to buy custom springs.
E300 Turbo Diesel; Level 2 Chip, AFE Air Filter, Multi-function Steering Wheel, Multifunction Display, Euro Comand 2.0, DVD in Motion, Argos Bluetooth, Comand Controllable DVD/MP3, Ashtray delete, XM Radio, Active Ventilated Front Seats, Parktronic, AutoMeter A pillar Boost Meter, H&R Springs, AMG Multi Spoke Wheels, LED Tail lights, Power Folding Blinking Mirrors, AMG Front Bumper, AMG Rear Bumper, Carlsson Side Skirts, Eisenmann Race Exhaust.
husk is offline   Reply With Quote
Old 07-20-2008, 05:43 PM   #5 (permalink)
Date registered: Mar 2008
Vehicle: 2000 E430 4M
Yeah good luck finding them too. $799 from lorinser just for the springs, some guy on here was ordering them from Germany, he should have his 430 4m lowered by now, do a search. I guess the main spring mfgs, like eibach, intrax etc, just didn't bother to fab up a 4M spring when the 210 came out. Since our springs sit on top of the shock, unlike RWD, you should also look into custom coilovers since you may want to change the shocks too.
I just swapped in new Bilstein HD shocks with the factory springs and I'm sporting the jacked-up 4x4 look. Not the smoothest looking, but I can handle steep parking lot dips and driveways w/o the worry of bottoming out and scraping up the underbelly... I drove a slammed awd eclipse for a few years before the whole fast and furious thing happened and shamed the import community lol, and I routinely scraped the underside of that car. It seriously changes your ability to access certain places.
I guess I'm trying to make this the most useful comfortable daily driver ever, though it would look better slammed to the ground with 19's.
Good luck on lowering the 4M, please post your findings!
Cbus_E430 is offline   Reply With Quote
Old 07-20-2008, 08:50 PM   #6 (permalink)
ohlord's Avatar
1/2 coil
measured directly across the spring and cut with a cold saw will not affect the tension in the coil,a coil that has been around along time has a set memory and when cold cut will not sag and since it already has a memory it will not drop like aftermarket springs that take months to settle in.Final ride height can be adjusted with the pads and about 16mm over the range of several pad thicknesses.
ohlord
What is unsafe about a cold cut spring?We have been doing them for years and most often with better tuned results than pricey custom springs.They are made and cut,so what makes a new cut unsafe?Cold cut saw is the key
Old 07-20-2008, 10:50 PM   #7 (permalink)
it is illegal and dangerous to cut springs. If you do it properly it might work, but I wouldn't be giving this type of advice over a forum. Imagine the liability issues if its done improperly? Your springs will be very stiff if you do cut them (i.e. every piece of gravel, road impurities etc will be felt). DO you know the wire thickness of 4 matic springs? What about the active coils? Without knowing this information I would be scared to advise someone to cut their springs. If you cut your springs chances are your car will ride like crap. A 4 matic benz is much more complicated than the non-4matics so I would be very weary of doing this.
Old 07-21-2008, 12:22 AM   #8 (permalink)
ohlord's Avatar
1/2
coil max is all i am suggesting,have you ever compared an oem spring to an amg spring ?several fewer coils and all cut fro a cold extrusion spring former.1/2 coil measured across the springs diameter will not be an issue,will change ride quality less then h/r or eibachs and have no need to wait for the springs to settle before getting it properly aligned.
who said it is illegal to chop a spring?nobody,no law anyplace.the springs of a 4matic are no more complicated than a rwd just different length.cold cut them and your ride will close up the gap and firm up a bit,but the 4matic can use some firming up since it rides like a boat anyway.
Old 07-21-2008, 06:51 PM   #9 (permalink)
check your local code, it is illegal in most states to cut springs, and most shop won't even cut springs, because they can lose their license if they are caught cutting springs.
Old 07-21-2008, 10:26 PM   #10 (permalink)
ohlord's Avatar
You are
in california land of cut springsthey were invented there.i could find a 100 places within in a close range of you to chop a spring.Any fab shop,hot rod shop,a quality saws all in a vise in your own shop.
ohlord
2 coils cut
Lowering C350 4matic nnnnny W204 C-Class 1 05-08-2008 01:43 PM
Lowering 4Matic Syn3rgy W203 C-Class 0 11-29-2004 09:54 AM
lowering a 4matic andreg W203 C-Class 1 05-25-2004 07:53 PM
lowering a C240 4MATIC marshallgp84 W203 C-Class 1 11-11-2003 09:24 PM
Lowering Springs for 4matic Buckz W210 E-Class 7 07-11-2003 10:43 AM
