» Site Navigation
» Other Sites
Old 07-18-2008, 01:05 PM   #1 (permalink)
Date registered: Aug 2007
Vehicle: W210 1998 E430
Noisy A/C compressor?
Hi all,
1998 E430 - when I start the engine, I notice a slight squeaking noise coming from the engine bay. It is loud at first then gets quieter and after a minute or so it is barely audible. Pushing the EC button on the climate control silences the noise, so I am guessing it is the A/C compressor?
Bearings? Is this unit serviceable? A/C is working fine at the moment, nice and cold.
TIA.
Benzboy210 is offline   Reply With Quote
Old 07-18-2008, 01:36 PM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Before you do anything, check the clutch gap. An excessive gap can cause slipping upon startup.
Old 07-18-2008, 02:14 PM   #3 (permalink)
Thanks Matt. I don't have a clue about the compressor, never worked on one. What should the gab be? Thanks!
Old 07-18-2008, 02:36 PM   #4 (permalink)
A typical compressor uses a .020" gap (.5mm). I don't recall seeing the spec in the FSM, but it must be there somewhere.
The gap grows with age, and is adjusted by changing (or removing) shims behind the clutch.
Old 07-18-2008, 07:00 PM   #5 (permalink)
Date registered: Aug 2006
Vehicle: 1999 E300DT
When I replaced my clutch, the instructions in the kit specified 0.45mm, +0.15mm or -0.10mm.
The preload of the belt will affect the gap so you'll want to finally set it with the belt installed.
Here's what I went through and the writeup I did about it:
http://www.mercedesshop.com/Wikka/W210CompressorClutch
1982 320i
1999 E300DT
2005 Pathfinder LE
Dave1965 is offline   Reply With Quote
Old 07-18-2008, 07:53 PM   #6 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Originally Posted by Benzboy210 View Post
Hi all,
TIA.
If you start by making assumptions instead of following normal diagnostic and troubleshooting steps you will spend lots of time and money or both.
Cycling the compressor loads and unloads other pulleys, so it is entirely possible it is your idler pulley, tensioner or even maybe the water pump or alternator.
So instead of sitting in the car and pushing buttons, grab your mechanic's stethoscope and carefully ISOLATE the source of the noise. If it is indeed the compressor then you can dig in further...
Take care and enjoy the ride,
Greg
Old 07-18-2008, 08:10 PM   #7 (permalink)
MercedesShopWiki: A/C Compressor CLutch Replacement
Thanks, Dave. I still haven't checked the FSM for the proper gap.
But Greg is right on yet again. Get a stethoscope and go hunting. You might need to have an assistant start the engine.
Old 07-19-2008, 06:33 AM   #8 (permalink)
Greg
Good point, but would the compressor's load make that much of a difference? Either way, it's sound advice (no pun intended), so I will isolate the noise.
Old 07-22-2008, 06:37 AM   #9 (permalink)
So I tried to isolate the noise and it definitely appears to be coming from the compressor, but I can't be 100% sure. The other tricky part is that the sound goes away after a minute.
Matt - I can freely turn the front of the compressor with the engine off.
I think for now I may just leave it unless the noise worsens. I'll keep an eye (ear) on it. Thanks all.
Old 07-22-2008, 07:54 AM   #10 (permalink)
The compressor is actually turning when this noise occurs?
ANyone know how to replace compressor clutch on OM617 while compressor still attached to loss W123 E,CE,D,CD,TD,TE Class 13 07-28-2008 07:32 AM
Noisy compressor...please help. joshtx W123 E,CE,D,CD,TD,TE Class 6 08-03-2006 07:00 AM
Very noisy suspension compressor pump glassdome W220 S-Class 5 11-25-2005 08:09 PM
$15 5-in-1 air compressor for those that bought used SLKs with missing compressor Black98SLK230 R170 SLK Class 2 11-29-2004 03:20 PM
Not satisfied with the car (Noisy! Noisy! Noisy!) Guest (MBNZ) W203 C-Class 3 05-21-2001 04:35 PM
