PO301 code, Diagnostic Help Needed - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 07-17-2008, 08:40 PM Thread Starter
Date registered: Sep 2007
Vehicle: 1997 E420, 117,000 mls
Hello All:
I've replaced the plug, connector, coil and injector on cylinder #1 but I'm stilll getting PO301, misfire on # 1 cylinder. The misfire is very slight and only noticeable at idle. I'm wondering what else could be at fault ?
Cheers, Chato
"The greatness of a nation and its moral progress can be judged by the way its animals are treated." Mahatma Ghandi
Chato is offline
post #2 of 8 (permalink) Old 10-23-2008, 05:59 PM
Date registered: Oct 2007
Vehicle: 2003 C230 Sport Coupe
I have the same problem with my 2003 c230. My car's idling low and it seems to bottom out at times, which leads to roughness and the check engine light comes on. I've changed spark plug seat as per the stealership (fixed for one day) then the plugs. Next is wires and coils I guess!
S2art is offline
post #3 of 8 (permalink) Old 10-24-2008, 04:40 AM
unitfreebie's Avatar
Vehicle: 2006 CLK 350
Check the appropriate CAT converter and O2 sensor...
: MBZ 280E, 260E, 300SD
MBZ 190E, E320W, CLK350
unitfreebie is offline
post #4 of 8 (permalink) Old 10-24-2008, 04:24 PM
Date registered: Dec 2007
Vehicle: 2002 e320 4 Matic Wagon
I had this problem, finally it was the coil that was too tight.Don't overtighten it.
Hi Fi is offline
post #5 of 8 (permalink) Old 10-24-2008, 05:38 PM
Exclamation New Defective Coil !!!
I would return the coil as defective and get another one that works when tighten to the specified torque. If just tightening the bolt causes pressure on the epoxy resulting in a bad internal connection, then it will eventually fail or cause problems down the road.
Are the coils genuine MBZ or 3rd party source?
post #6 of 8 (permalink) Old 01-17-2015, 12:11 PM
Date registered: Jan 2015
Vehicle: 2003 c 230 K
Unhappy
2003 230 K I've replaced the plug, connector, coil and injector on cylinder #1 but I'm still getting PO301, misfire on # 1 cylinder. The misfire is very slight and only noticeable at idle. I'm wondering what else could be at fault ?
skyles is offline
post #7 of 8 (permalink) Old 01-17-2015, 03:07 PM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 399 Post(s)
put the coil. plug, connector and injector in cylinder #2 . if it follows, then move parts back one at a time. If it doesn't follow, then something else is giving the misfire.
--------His------------Hers-------
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
post #8 of 8 (permalink) Old 01-17-2015, 07:13 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Have you done a compression check?
Check Codes is offline
Diagnostic Code Reader pguard W202 C-Class 36 11-26-2013 10:39 AM
Diagnostic Code Reader woodyww W163 M-Class 9 06-30-2009 12:26 AM
4206 Diagnostic Code enda W203 C-Class 0 12-19-2005 11:24 AM
what does the Diagnostic code mean? qha000 General Mercedes-Benz 1 11-04-2005 11:14 PM
Need help with Diagnostic code qha000 W140 S-Class 5 11-03-2005 07:55 PM
