Old 07-15-2008, 10:41 AM   #1 (permalink)
Date registered: Jul 2008
Main Odometer
Hello all;
I have a E 240 2003 , the problem is that i can't see the main odometer , it's only showing dashes no numbers at all.
can anybody help me out with this?
thanks
Racham is offline   Reply With Quote
Old 07-15-2008, 10:18 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hi, Racham and welcome to the forum. Please take a minute and complete your BW online profile re: vehicle and location as that is very helpful information.
I would first try rebooting the car and if that doesn't do anything then pop the cluster and swap a couple of the same-colored base bulbs to the odometer location. If that still doesn't take care of it then you have the dreaded pixel issue, there are some tips on trying to fix it yourself, failing which you have to decide whether you want to live with it, send it out for repair (and keep your fingers crossed) or buy a new one.
Good luck and keep us posted,
Greg
Meister Eckhart
digital odometer and trip odometer no longer illuminate S320_on_18s W140 S-Class 3 05-27-2008 08:14 PM
Odometer and Trip Odometer not working houston14 R129 SL Class 1 05-27-2008 05:39 PM
Main Harness motorwerke R230 SL Class 0 05-12-2006 12:27 AM
Main Distributor Overfeeding modulacom W126 S,SE,SEC,SEL,SD,SDL Class 6 10-04-2005 06:34 PM
Odometer/trip odometer stopped working theratpatrol R/C107 SL/SLC Class 8 07-23-2005 09:12 PM
