Old 07-07-2008, 09:32 PM   #1 (permalink)
nugent's Avatar
Date registered: Jul 2005
Vehicle: Self: 2000 E320 83,000 mi Girlfriend: 1998 E320 134,000 mi
Question Transmission Fluid on eBay
I found this on eBay:
eBay Motors: 3 - OEM Mercedes Automatic Transmission Fluid Genuine (item 320269608114 end time Jul-08-08 10:17:04 PDT)
Is this the real deal? Kosher for my 2000 E320? Look at the back label.
I have never bought from the dealer, so have no comparison.
nugent is offline   Reply With Quote
Old 07-07-2008, 11:23 PM   #2 (permalink)
ohlord's Avatar
Inquire
as to whether it is 722.6 spec.
They state for all mb trans which clearly shows they know not of what they speak.
a 722.9 7 speed can not use 722.6 fluid and a 722.4 or 722.5 can not use 722.6 fluid For the price if a transmission I would get it shipped free from autohausaz.com for $14.91 a bottle and that way you are sure it is the real deal.
I have the special dip stick and free pan magnet for $42 delivered.
autohausaz.com has the filter and gasket.
ohlord
Old 07-08-2008, 06:10 AM   #3 (permalink)
Date registered: Sep 2004
Vehicle: 98 E-320
Part #001-989-21-03-10 is the proper 722.6 spec AT fluid.
You end up paying 35.00 for 3 after shipping. Depend on how many you're going to get, ask them for a shipping discount.
Good luck.
JeffreyP is offline   Reply With Quote
Old 07-08-2008, 06:26 AM   #4 (permalink)
Date registered: Apr 2008
Vehicle: 2002 E320 Wagon, 88 Saab 900T convertible, 86 Toyota MR-2
They are only charging 6 bucks shipping for each additional 3 bottle purchase. So, that's only $61 for 6 bottles and they have several sets available for purchase. This looks like a decent deal to me.
My car currently has 72K on it so I think I may jump on this.
M Hiby is offline   Reply With Quote
Old 07-08-2008, 12:46 PM   #5 (permalink)
ohlord's Avatar
Somebody
recently found the backwards compatible 722.9 fluid at their dealer for $11 a bottle.You might call yours
ohlord
I have the dipsticks and free magnet ready to ship.
ohlord
Old 07-08-2008, 02:45 PM   #6 (permalink)
ohlord
ohlord
COOL! Thanks. I will look into that. I am sure the ebay seller is not going away anytime soon so I can always go back to it if need be. I will be getting the stick from you as soon as I am ready to do the change.
Old 07-08-2008, 02:56 PM   #7 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Just my .39 worth (inflation, you know), but since you don't have a converter plug you're not going to be able to change much. Personally I would consider dropping the pan, measure what you take out, swap out the filter, clean everything up and put the pan back on, then refill with what you measured out. Then use yumling's great DIY to use the transmission to cycle out the rest of the fluid, adding as necessary per the DIY. You'll need a lot more fluid, but then you're sure you changed out virtually all of it and you're good for another 75K. Cost-wise it's probably cheaper to do the partial change every 30K or so, but I'd rather do it and forget it.
Take care and enjoy the ride,
Greg
Meister Eckhart
Transfer Case fluid and Transmission Fluid clb0099 W163 M-Class 4 01-12-2008 09:59 PM
Transmission Fluid Change, how much fluid? slk230red R170 SLK Class 5 03-07-2007 10:06 PM
How often to change transmission fluid-filter and diff fluid? Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 14 08-17-2006 05:31 PM
Transmission Fluid in the Power Steering Fluid reservoir ldshull Vintage Mercedes-Benz 4 06-12-2006 11:59 AM
Transmission fluid change - what fluid ???? Anjey W126 S,SE,SEC,SEL,SD,SDL Class 9 05-10-2005 01:18 PM
