Old 07-07-2008, 12:15 PM   #1 (permalink)
ETP
ETP's Avatar
Date registered: Sep 2007
Vehicle: 99 E-430 w/mods 98 E-320
Engine Oil
What engine oil do you use? I have always used Mobile 1. I have an opportunity to buy Valvoline or Pennzoil Synthetic for $3.50 per qt vs $6.00 for M-1. I have always believed that you get what you pay for...comments / opinions?
ETP is offline   Reply With Quote
Old 07-07-2008, 12:31 PM   #2 (permalink)
gatonls's Avatar
Date registered: Jun 2008
Vehicle: 97 E320, 05 328, 01 Jeep
I would stiay with the M-1 euro blend........Your choce! Not sure what Valvoline or Pennzoil are rated for?
gatonls is offline   Reply With Quote
Old 07-07-2008, 01:03 PM   #3 (permalink)
Date registered: Aug 2007
Vehicle: W210 1998 E430
Use an MB-approved oil, minimum spec is MB 229.3. I use Castrol Syntec 0W30 (Made in Germany), MB 229.5
Read this page - Mercedes-Benz Engine Oil Recommendations
Benzboy210 is offline   Reply With Quote
Old 07-08-2008, 08:53 PM   #4 (permalink)
Date registered: May 2008
Vehicle: 99 E320
I stick with Mobil 1 0W40.
99 E320
02 Land Rover Discovery
05 Land Rover LR3
dcwhybrew is offline   Reply With Quote
Old 07-09-2008, 01:11 AM   #5 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
I too use Mobil1 0W40, in large part because it is the least expensive MB spec oil I can find. There are many other options but whenever I stumble across one of them they're more expensive.
If the other synthetics you are considering state on their label that they meet or exceed MB spec 229.3 then you will be using oil that MB approves, so it shouldn't be an issue.
Take care and enjoy the ride,
Greg
Meister Eckhart
How much engine oil to bring oil level from min to max? allerton W126 S,SE,SEC,SEL,SD,SDL Class 15 07-26-2006 06:50 AM
Oil Extreme - Engine oil additives anilasher General Mercedes-Benz 3 10-05-2004 09:54 PM
Someone Drained the Tranny oil instead of engine oil ae86pwr W163 M-Class 8 06-09-2004 09:00 PM
Do you have to add engine oil before FSS oil change??? 00 ML430 Bulldog W163 M-Class 2 02-07-2004 03:59 PM
My 96 S320 to have a cracked engine block gasket, which cause a oil leak .All oil changes (more)... Guest (MBNZ) W140 S-Class 2 04-19-2002 02:34 PM
