Old 07-06-2008, 01:34 PM   #1 (permalink)
Date registered: Jul 2008
driverside a/c not cool
driverside a/c blows warm
blackdog16@HUGHES.NET is offline   Reply With Quote
Old 07-06-2008, 04:11 PM   #2 (permalink)
ohlord's Avatar
Run
the diagnostics
How to Diagnose Air Conditioning Malfunctions | EclassBenz.com
post the values
either low r134a or most likely stuck duo valve
ohlord
Old 07-07-2008, 12:15 PM   #3 (permalink)
nugent's Avatar
Date registered: Jul 2005
Vehicle: Self: 2000 E320 83,000 mi Girlfriend: 1998 E320 134,000 mi
My experience is low refrigerant. For some reason passenger side blows cold before driver's side. Top up R134a and the driver cools down.
nugent is offline   Reply With Quote
Old 07-07-2008, 12:38 PM   #4 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
That is a common fault, but by far not the only possibility. Don't add refrigerant without determining if you really are low, or you can cause damage to the system.
My system was blowing warm from the driver's side vents, but it was not because of low refrigerant level. Rather, there was a restriction in the system preventing proper refrigerant flow. In addition, if the restriction is before the pressure sensor (as was the case on mine), the pushbutton unit will not be reading the actual high-side pressure and thus won't be able to shut down the compressor when the head pressure gets too high.
My pushbutton unit showed 3 with the compressor running, but the high-side port showed 350 psi.
WTB: 96 s500 Driverside window itzkhoa For Sale, Trade & Wanted Items 1 04-24-2008 07:42 AM
Driverside mirror glass $450 RichRocky R170 SLK Class 7 02-28-2008 04:43 AM
driverside door hinges snyder.hunter G-Class 0 01-08-2008 06:20 AM
driverside mirror help riz W210 E-Class 4 11-16-2004 01:06 PM
Front Driverside window switch Silver300e W124 E,CE,D,TD Class 2 08-07-2004 03:57 AM
