Old 07-05-2008, 09:11 PM   #1 (permalink)
Date registered: Aug 2007
Vehicle: 1998 E320 4matic wagon
Sunroof binding anyone used MB specific grease
From what I have read this is the one and only grease to use on the sunroof tracks. My problem is the SR goes back just a few inches and at that point the two wire spring cables on both sides jump out of the track and toward the center of the car. But the link that shows the sunroof repairs also mentions that no lubrication should be made? Anybody had the same problem fixed with MB grease?
korbenz is offline   Reply With Quote
Old 07-06-2008, 10:45 AM   #2 (permalink)
Musikmann's Avatar
I have not but I read in the owner's manual that the tracks are a regular maintenance item. I can't remember if they recommend every 2 or 3 years.
Old 07-06-2008, 04:06 PM   #3 (permalink)
Date registered: Oct 2007
Vehicle: 1996 E300D
Sunroof grease
Special sunroof grease is sold by Mercedes in large quantities for large prices. You can buy a small amount (35mm film can) here. You may have to ask them for a quote, I don't see a specific listing but that's where I bought mine.
Our all-diesel family
1985 300D Turbo California (W123), 230000 miles, on B100 since Apr '06
1987 300D Turbo (W124), 138000? miles, on B100 since Jan '07
1996 E300D (W210) 251000 miles, on B100 since Nov '07
1988? Satoh Beaver garden tractor, on B100 since 2004.
Jeremy5848 is offline   Reply With Quote
Old 07-06-2008, 06:03 PM   #4 (permalink)
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320
Sunroof Lube
The Clean/Lube is specified by WIS as:
"EVERY 5 YEARS"
The lube is 001 989 84 51
Perhaps it's just because I have a good relationship with my local dealer here, but for nit-picky items like this where you need a whopping 4 0r 5 cc's of material, I just flat out ask them if I can have some of their stock, rather than buy a 55 gallon drum of the stuff.
My philosophy is, "It doesn't hurt to ask".
Here's the directions for the job:
G-AMG is offline   Reply With Quote
Old 07-06-2008, 06:20 PM   #5 (permalink)
Musikmann's Avatar
"EVERY 5 YEARS" The lube is 001 989 84 51
Thanks for correcting my mis-informed answer G-AMG.
Old 07-06-2008, 06:27 PM   #6 (permalink)
TNTRower's Avatar
Date registered: Sep 2007
Vehicle: 1998 E320 Wagon
Smile Quick search for "Sunroof Lubrication."
Here is your answer in the forum.
http://www.benzworld.org/forums/w210...of+Lubrication
Who's John Galt.
"Timeo Danaos et dona ferentes" - Virgil, The Aeneid, Book 2
TNTRower is offline   Reply With Quote
Old 07-06-2008, 07:15 PM   #7 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
Sounds more like you need to upgrade the guides that hold the cables in the tracks. They were changed in 2000 and are $4 each.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 07-06-2008, 07:24 PM   #8 (permalink)
Thanks guys
I will try to round up some of this Klueber polylub at the dealer, or if that doesn't work I'll buy a little.
I got a sunroof quote at Hoen (my local dealer) a long time ago, $1200.
No thanks
Old 07-08-2008, 01:16 PM   #9 (permalink)
the guides were upgraded?
That might be the fix.
I took G-AMG's advice and the dealer gave me the sunroof lube. It looks like industrial strength petroleum jelly, still the cables pop out as soon after the sunroof starts opening up. and it pops out right where there is an access cover plate, that might be the problem.
Thanks
Old 07-11-2008, 03:54 PM   #10 (permalink)
two new guide covers ($3 each) fixed it
It needed to be lubed for sure, but even after the lube, the cables still popped out where the cable cover access plate is.
The new cover plate has two screw holes, not one, and it stays in place. First time the sunroof has worked in a long time
Sunroof grease? mr.xpowerseller W126 S,SE,SEC,SEL,SD,SDL Class 18 03-26-2008 11:36 AM
Sunroof grease question mazur W126 S,SE,SEC,SEL,SD,SDL Class 8 04-24-2007 01:34 PM
Sunroof Binding Wayneb W124 E,CE,D,TD Class 4 01-04-2007 02:09 PM
90 300GD steering binding achova G-Class 4 05-12-2005 10:10 AM
MB sunroof grease Snibble W126 S,SE,SEC,SEL,SD,SDL Class 6 06-09-2004 09:11 AM
