Old 09-04-2008, 07:57 AM   #21 (permalink)
Date registered: Aug 2007
Vehicle: W210 1998 E430
Originally Posted by BJafari93 View Post
Where exactly is the screw to do this? I drilled the hole but couldnt find the screw?
Screw is on the steering shaft. Check out the diagram as CWood mentioned. You may need to shine a small flashlight into the hole you drilled to see it. It's a small brass Philips screw.
1998 E430, Alexandrite metallic green, anthracite black leather interior, BOSE audio, factory xenons, AMG suspension, W211 E500 sport wheels with RAD bolts
Benzboy210 is offline   Reply With Quote
Old 09-04-2008, 02:38 PM   #22 (permalink)
Date registered: Apr 2007
Vehicle: 2001 SLK 320(96K Miles), 2002 E320 Special Edition(113K Miles)
His location is not in his profile. So he may have a right-hand steering - in which case it may be on the opposite side?
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians (and lawyers) are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline   Reply With Quote
loose steering shaft sleeve Art W210 E-Class 3 07-02-2008 06:51 AM
loose door on 240D; easy fix? oregonscott W123 E,CE,D,CD,TD,TE Class 1 08-03-2007 04:15 PM
wiper shaft quick question Desertstar G-Class 6 02-21-2006 09:02 AM
Any fix for loose steering wheel rubber? Benz4Time W126 S,SE,SEC,SEL,SD,SDL Class 0 08-08-2004 03:50 PM
Sloppy or Loose Steering problem check with fix. stinger R/C107 SL/SLC Class 1 02-08-2004 09:11 PM
