Old 07-18-2008, 06:02 PM   #11 (permalink)
Date registered: Aug 2007
Vehicle: W210 1998 E430
Just wanted to add a wrap-up pic...I used a black trim grommet to plug the hole. It blends perfectly and can easily be removed the next time I need to adjust the stalk.
Benzboy210 is offline   Reply With Quote
Old 07-18-2008, 07:15 PM   #12 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Nice pictures. Why don't you nominate the thread for one of the DIY stickies?
Old 07-19-2008, 06:49 AM   #13 (permalink)
Nominated!
Thanks again to Art for the tip!
Old 07-19-2008, 08:48 AM   #14 (permalink)
99EBenz's Avatar
Date registered: Mar 2008
Vehicle: 1999 MB E320 - Brilliant Silver/Ash (stock) - MBCA Member
Good idea! Where did you acquire the plastic grommet? Mine is loose also but not to the point yet of having to go to the trouble to tighten.
EBenz
99EBenz is offline   Reply With Quote
Old 07-19-2008, 09:01 AM   #15 (permalink)
EBenz - got it at Canadian Tire for about $0.10.
I'm sure any auto parts store in the US will have the same. The grommets are usually located along with other miscellaneous trim parts like door lock knobs, mirror covers, etc.
Old 07-19-2008, 09:22 AM   #16 (permalink)
Originally Posted by Benzboy210 View Post
Nominated!
I mean, please post a message to this thread:
http://www.benzworld.org/forums/w210...y-threads.html
Old 07-19-2008, 09:28 AM   #17 (permalink)
Ah...done.
Old 07-22-2008, 12:22 PM   #18 (permalink)
Date registered: Jun 2008
Vehicle: 1998 E320 on 18's
Thumbs up Awesome 3 minute repair!
Thanks Benzboy210.
I was tempted to give the drill a try on my own but after your pictures, I was sold on taking the easy approach. It took me a total of three minutes and one minute was going back to my toolbox to get a smaller phillips head screw driver to get the best grip. The hole cannot be noticed and will be plugged as suggested.
Thanks again. This is a first class "flat rate" repair.
CWood - Phoenix, AZ
CWood is offline   Reply With Quote
Old 08-29-2008, 06:16 PM   #19 (permalink)
Date registered: Feb 2008
Where exactly is the screw to do this? I drilled the hole but couldnt find the screw?
BJafari93 is offline   Reply With Quote
Old 09-03-2008, 03:43 PM   #20 (permalink)
Search for the DIY regarding this issue. It shows removing the steering wheel, air bag, etc. You can see the clamp and screw in the picture. It is located off to the side at at a small angle...
loose steering shaft sleeve Art W210 E-Class 3 07-02-2008 06:51 AM
loose door on 240D; easy fix? oregonscott W123 E,CE,D,CD,TD,TE Class 1 08-03-2007 04:15 PM
wiper shaft quick question Desertstar G-Class 6 02-21-2006 09:02 AM
Any fix for loose steering wheel rubber? Benz4Time W126 S,SE,SEC,SEL,SD,SDL Class 0 08-08-2004 03:50 PM
Sloppy or Loose Steering problem check with fix. stinger R/C107 SL/SLC Class 1 02-08-2004 09:11 PM
